Go to Amazon. Type in Armani watch spares/repairs. If no supplier is shown on Amazon, scroll to the bottom of the page. There you will find alternative web sites listed. Some are rubbish search sites but some will be genuine suppliers.
how to tell if armani watch is fake or real, its near impossible ! its one of the easiest watch to copy, the movement is much the same, armani use seiko! most copies are as good has the original, and the time and effort put into making it are much the same!
mcdevito75 here, There are 2 ways to wind your Armani Emporio watch, I'm figureing it"s an automatic watch, on some automatics you can start an initial ticking by winding the stem in any direction, if when you wind the stem you feel any resistance then this is the type of automatic watch you Start with about 20--30 winds of the watch. If on the other hand when winding the stem feels very loose and free, no resistance at all, then this is the type of automatic that relize on pure wrist and arm motion to start ticking, simply hold the watch in your hand and make small circle motions, or rocking motion, you should detect something moveing inside the watch, this is the winding counter balncer it's normal, rock or circle the watch for approx. 30 seconds to get it started. In both cases, after the watch starts, the motion of your wrist / arm keeps it wound as you wear it.
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
The Armani site is not very helpful but try this one:-
The year should change when the month hand passes from December to January.
If you pull out the winder (it may need to be screwed out anticlockwise first), you should be able to find a position where the month can be changed. Wind the month hand passed December. If you need to advance it more than one year, then wind it backwards from January to December and then forwards again to January.
