Canon PIXMA MP210 Photo All-In-One Printer Logo
Posted on Dec 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to refill canon 38 cartridge - Canon PIXMA MP210 Photo All-In-One Printer
Anonymous
Level 2:
  • Expert 159 Answers
  • Posted on Mar 08, 2010
Anonymous
Expert
Level 2:
Answers
159
Questions
0
Helped
92624
Points
271
You can't refill the cartridge that's in your printer because your printer remembers the serial codes in the electronics of the cartridge to reject refills. I own a Cartridge World ink refilling store and I have started suggesting that customers buy Canon originals because we have had so many returns.
How to change ink in canon mx492
Replacing Canon ink jet cartridges can be expensive. On the off chance that you have a shading printer, the expense of the ink may include rapidly. Most Canon cartridges are refillable, and you can set aside some cash by supplanting the ink yourself. Refilling Canon Printer cartridges can be cultivated by getting an ink refill pack so you can refill your cartridges at your home.
Check your Ink Cartridge
Method 1:
1. Make beyond any doubt the ink cartridge is vacant.
• Many Canon ink jet cartridges have an electronic device that counts down with every character printed.
• When the counter reaches 0, you will get an error message on your printer.
2. Follow manufacturer's directions to remove the Canon ink jet cartridge.
3. Look to see if the ink reservoir is empty.
• On the off chance that there is still ink in the store, reinstall the cartridge, and when you get another mistake message, push the "alright" catch to keep printing.
4. If the cartridge is empty, refill the Canon ink jet cartridge.
Method2. Refill your Ink Cartridge
1. Acquire an ink refill pack at an office supply store or online. To refill canon ink cartridges, you need a 30 cc syringe with a needle, a thumb drill and printer ink.
2. Place the ink holder on paper or paper towels. When refilling Canon cartridges, you may have some ink spillage.
3. Select the ink. For example, on the off chance that you are refilling your yellow ink cartridge, you will require yellow ink.
4. Put the needle on the yellow ink holder.
Method 3: Replace Ink
1. Discover the opening where the ink originates from. This will be situated on the wipe region of the cartridge.
2. Crush two or three drops of the right shading ink on this opening to fill the wipe with ink.
3. Tape the leave opening with tape to avoid ink spillage while you complete the process of refilling Canon cartridges.
4. Drill a little opening in the ink cartridge with a thumb boring tool underneath the cartridge mark.
• Look on the cartridge for a letter meaning the shade of the ink, and underneath it, a hover with a dimple in it.
• When you refill ink cartridges, you need to penetrate the opening amidst the dimple.
5. Set the needle into the opening you made in the cartridge, and cautiously push in the ink. When refilling Canon cartridges, watch the cartridge with the goal that you don't overload it.
6. Remove the needle from the cartridge, take it off the compartment, and set the top back on the ink so it won't spill.
7. Seal the gap with paste, hot wax or electric tape when you wrap topping off Canon cartridges to anticipate spills.
8. Remove the tape you put over the wipe region.
Method 4: Reinstall Ink Jet Cartridge
    1. Introduce the cartridge and select upkeep on your printer.
    2. Run your printer through its cleaning cycle when you refill ink cartridges.
    3. Give the refilled cartridges a chance to set inside the printer for around 8 hours with the goal that the wipe drenches up all the new ink.
    For any other queries please contact Canon Printer Support and if you want to see video that how can you refill the Canon Cartridges. So Please CLICK
Ink refill problems
This model Canon printer may only let you use genuine Canon/Epson printer cartridges. If you try to refill these ink cartridges it will not work because the Canon cartridges have an embedded chip in the cartridge that detects the empty cartridge even though it has been refilled.
Does ink refile is possible in canon ip 2770 printer?
Yes, Canon ink cartridges can be refilled. Most Canon cartridges can be refilled up to 12 times. Canon cartridges consist of a sponge and an open ink reservoir, so they can be refilled using a syringe.
Where do you get refill ink for canon fax phoneL80
The Canon Faxphone L80 takes a Canon FX3 cartridge. To get the highest quality refill I would first see if there is a Cartridge World store in your area. Cartridge World stores refill most cartridges in house with American made parts. Then try Office Depot. Office Depot is the only big box store that actually "remanufactures" toner cartridges. I would not recommend cheap refills or refill kits from the internet. Many use very low quality toner that wears on parts leading to print defects or they reuse parts that already generate print defects. DO NOT buy a "compatible" cartridge, these are not refills. They are new cartridge replicas and have no recycled components.
No problem. What is the step by step instructions
go here
http://support.medea.co.uk/download.php?FLIB=1&id=8
this is a
Refill Instructions for -
Canon PG-37/PG-40/PG-50
CL-38/CL-41/CL-51
as bdf file
i hope that helps
Incompatible cartridges
I don't have an MP145 but from what I know that printer uses the 830/831 and 40/41 canon cartridges. I'm not familiar w/ the 37/38 as we don't have it here but from the pictures that I've seen they look identical. Unfortunately, Canon may have done some region coding like HP as I've only seen the 37/38 in the European websites. You can try it but I would suggest you changed it to the 40/41. Also if you have the original box of the printer, it should indicate there what cartridges are compatibe. If the 37/38 is not written on it then its not compatible. Hope this helps.
3helpful
2answers
Refilling cartridge
check this video it is very easy with no special equipment
http://www.youtube.com/watch?v=iMiTopIVMxM
I am trying to reset the empty ink cartridge error code on a Canon mp-530 multifunction printer after installing a refilled a refilled black ing cartridge
Hi, did you refill yourself or did you buy a refilled cartridge. If you purchased a refilled cartridge and the chip is missing, you will need to take the chip off your old cartridge and install on the refilled cartridge.
old marine
old marine
ZJ Limited
ZJ Limited
