Question about Honeywell Humidifiers
How can I get a manual to put together a HCM6013i humidifier . Honeywell Brand I have put it together, all the lights are on but there seems to no electricity getting to it to make a fan (I think) work
    New Friend:
Returned it for a replacement the motor was broken
Posted on Jan 02, 2010
Replaced the Filter Now water leaks from the bottom
sounds like u didnt get ur drain in the hole right or u didnt get the filtr in correctly take it back out and be gentle and put it back together and should fix the problem
Feb 25, 2010 | Honeywell HE365 Humidifier
Honeywell TruSteam Humidifier has a burnt out element
It sounds to me as though they have the market cornered on this unit. If it says the element is bad and they say they don't sell them, your only recourse is to but a new one. I think I would look into another brand, even though Honeywell are top of the line. It would seem to me if it says to replace it that it should be able to be replaced? I would call Honeywell myself and find out if I were you.
Shastalaker7
Dec 30, 2009 | Honeywell Power Humidifier: Furnace...
Honeywell Natural Warm Moisture Humidifier Is On But No Steam?
I have the same problem and I have 2 of them fairly new. I can't seem to find out what the problem is either.
Stumped?????????
Apr 10, 2009 | Honeywell Humidifiers
Honeywell TrueSteam Humidifier - I have 2 - one keeps flushing
don't know if this will help or not but dip switch 1 and 2 control the flush cycle on this unit. double check how they are set. the setting for flushing every 5 hours is not listed in the manual, but if both 1 and 2 are in the on position it will flush every 5 hours. hope this helps.
Jan 28, 2009 | Honeywell Power Humidifier: Furnace...
Honeywell HCM-525 owners/operation manual NEEDED PLEASE!
The filter should be located below the tank. the tank should lift off of the unit and there should be a rectangular cavity where the filter fits. You will most likely find the old filter dried up and filled with a white crust. That is salt and other minerals in the tap water that the filter catches.
Jan 01, 2008 | Honeywell HCM525 Humidifier
Open Questions:
Humidifiers Logo
91 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
