tHIS IS STRANGE BECAUSE IT IS ONLY A PLUG THAT GOES OVER A PIN IN YOUR SAT-NAVtHIS IS STRANGE BECAUSE IT IS ONLY A PLUG THAT GOES OVER A PIN IN YOUR SAT-NAV
You can't post conmments that contain an email address.
Using cable data /charger port you can do charging both at system or in car under car charger option. those specifications placed in manual and normally lasts for 3 hours
double check the connection. I had this with a one xl and it turned out to be a small bit of debris that had gotten into the car charger and stuck there so that even the home charger would not help.
I used a compressed air can for computers to blow it out..
also get a magnifying glass and check the connector strips inside the connector.
If you see damage it will probably have to got in for repair
You Can charge your Tomtom when you drive, or you can charge it with a USB port on your computer.
I don't think they come with a mains charger anymore?
TomTom One uses a Linear Technologies chip LTC3455 as a USB/charger power controller. See http://cds.linear.com/docs/Datasheet/3455fc.pdf. This chip is susceptible to high transient voltages that result from resonances created by parasitic inductances and capacitances of the USB/in-car charger cable . Good designs using this chip suggest that a 1 ohm resistance be put in the path of the cable to reduce the Q of the resonance and hence transient voltages. A 6V Zener diode D5 also serves to protect the chip from these transients.
If the Zener diode is blown it is most likely the the LTC3455 chip is gone as well. You can replace the chip which costs £5.00 (located in the shielded portion of the PCB). The recommended Zener Diodes for this chip are either the EDZ5.6B or EDZ6.2B manufactured by ROHM (http://www.rohm.com/products/databook/di/pdf/edz5.6b.pdf or http://www.rohm.com/products/databook/di/pdf/edz6.2b.pdf). These can be used to replace D5. The STMicroeletronics SM2T6V8A can also be used to replace D5 (http://www.st.com/stonline/products/literature/ds/8694/sm2t.pdf). All the Zeners cost a modest £0.22. I hope this is helpful.
Emmanuel Zyambo
From the sat nav itself :-s
