Question about Whirlpool Washing Machines
The control panel on my stackable washer and dryer got fried during a power surge. While the stackable is 8 years old, it still looks new and runs fine normally and has not been over used. The tech estimate is $250-300 but he says I should buy a new machine since my machine is older. With new stackables going at over $1000.00, and my rental property located out of state in Florida, I am thinking a fix is better. What do you think? Fix or buy new?
Posted by goodmerchn on
Minladar
  • 21 Answers
At 8 years old I think you got your money's worth out of it. (no offence) but if this is for a rental property and you are not close to repair any issues that may come up you have to ask yourself is it worth repairing a item that has and avg 10 years or less life span at 1/3 its cost to buy a new one. If you are not happy with the price of the newer units buy one from the loaner section of a home store or a scratch and dent unit then get the extended service contract with the money you save and you wont have to deal with this issue for 5yrs or more and should one come up you can have some one else deal with it.
Posted on Jun 25, 2017
5 Related Answers
Anonymous
SOURCE: Neptune stackable washer...
I went to Sears today and asked!  They said use high efficiency detergent (marked HE on the label) and put it directly in the washer with the clothes.  Mystery solved!
Posted on Aug 03, 2008
Anonymous
  • 750 Answers
SOURCE: Owners Manual for Sears Kenmore Stackable Washer/Dryer
Hello hboiler
Welcome,
You asked ,where can you download the owners manual for Sears Kenmore Stackable Washer/Dryer Model #417.91042000 and #417.41042000
Model #417.41042000
http://www.managemyhome.com/mmh/products/ManualSearch.action?product.brandName=Kenmore&product.modelNumber=417.41042000&intcmp=A5
Model #417.91042000
http://www.managemyhome.com/mmh/products/ManualSearch.action?product.brandName=Kenmore&product.modelNumber=417.91042000&intcmp=A5
Happy to help you!
Thank You for using Fixya.
Huuum
Please remember to leave a solved rating!
Posted on Oct 13, 2008
Anonymous
  • 113 Answers
SOURCE: Whirlpool stackable washer/dryer. Dryer squealing
Could be the idler pulley, or the dryer seals.
Posted on Dec 16, 2008
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Posted on Dec 25, 2008
Anonymous
  • 140 Answers
SOURCE: Can you move a stackable washer and dryer with it laying down.
It should be fine. Just make sure that any water that comes out doesn't get in the electrical parts of the units. Good luck. Any questions feel free to ask. Please rate me so I know if I helped you. Thanks.
Posted on Dec 31, 2008
Had a major power surge go through house now dishwasher doesnt work checked circut breaker is ok unit has power to it but wont turn on??
You probably have a fried control board. Better call a repair technician. But if the dishwasher is more than about 8 years old, maybe it would make more sense (cents) to go shopping for a new dishwasher.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Feb 14, 2015 | GE Dishwashers
We had a major power surge go through the house now our dish washer doesnt work breaker is on power is there ?
You probably have a fried control board. Better call a repair technician. But if the dishwasher is more than about 8 years old, maybe it would make more sense to go shopping for a new dishwasher.
No power to washer, dryer has bpower...
Might be a broken wire going down to the washer portion. I found that once on a stack dryer: Remove the control panel and look for a loose quick connect or broken wire.That was what was wrong with this un I think. Drop the splash pannel first then remove the screws to control and drop it out then check quick connects and wires is what I would do. -PawPaw
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 23, 2013 | Frigidaire Front Load Stackable Washer
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
My LG Tromm WM2277HB washer shut down during a power surge and will not power back on. Have unplugged for several hours, still no good. Looked at solutions posted on this site and it appears my PCB board...
Well I for one would go along with your prognosis, it seems logical to me.. this IS a common occurance when this type of thing, a power surge happens.. Remember Occam's razor.
Feb 05, 2010 | LG WM2277HBW XL Front Load Stackable...
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Can you buy a frigidaire stackable washer separately?
Have you had a qualified service man look at your machine? I would think that the burned rubber smell would direct you to examine the belt (found in the very bottom after removal of front cover).
If it is the belt it is a very easy fix on this machine. The not draining part wouldn't be related to the belt the pump that does the draining is driven by its own electric motor and is easily visible when the front cover is off. Its located on the bottom left side. If a sock or other small item manages to get over the side of the basket it always ends up jamming the pump.
You would have to take the pump apart to retrieve the item and restore pump function
Good Luck
Quentin
Aug 18, 2009 | Frigidaire FEX831CS Top Load Stacked...
Squeaky Kenmore Dryer
The idler rollera and belt tensioner have got bearings. One of them is failing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 07, 2009 | Dryers
Need to know age of stackable
I purchased mine brand new in 1993.
May 27, 2009 | Maytag LSE7806A Top Load Stacked...
What can cause a motor to burn out in a machine that is only 2 years old.
Hard to say.  There are a lot of issues that can cause this.  Let the repair person take care of it.
Jun 09, 2008 | LG WM2077CW XL Front Load Stackable Washer...
Washing Machines Logo
60 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
