Question about Hitachi 51SWX20B 51" Rear Projection Television
Hitachi TV model # 51SWX20B do i need a converter box for HD, or will direct tv HD-dvr work for my connection that say DVI-HDTV ?
Posted by keithlindner on
ladywinn
  • Hitachi Master
  • 5,138 Answers
No, you do not need convert box if your TV says HD on it!
Posted on Dec 31, 2009
I have a mitubishi ws-55313 with a monitor link DVI connection and I have tried to convert that to hdmi for a cable DVR but it doesn't work any ideas?
The monitor link is not a standard DVI connection, it was used to connect a Mitsubishi HD set top box. You can connect your cable DVR using component video cables and get HD that way, up to 1080i but not 1080p
Apr 15, 2014 | Mitsubishi WD-52525 52" Rear Projection...
Do you have to add a converter box to receive free
You will need a converter box or a separate tuner. The TV has an NTSC (analog) tuner.
I hope this helps.
(the $40 boxes that are available are mostly SD. You should check the specs if you want a HD tuner.)
May 30, 2010 | Hitachi 51SWX20B 51" Rear Projection...
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
Just bought blue ray player I have a hitachi plasma tv model pw1 32pd5000 how can I get blue ray to work with tv theres no hd outlet at the back of tv but it is hd compatible
The TV most likely will have component and a DVI connector on it if it doesn't have a HDMI connector. If the Blu-ray player has component connectors on it use them as they will give you up to a 1080i picture which is all this model of Hitachi supports anyway. If the player doesn't have component connections then you can get a HDMI to DVI converter cable so you can connect it to your TV. You will need a cable that looks like this...
http://www.kmart.com/shc/s/p_10151_10104_25000PCM-2296-06P?vName=Computers%20&%20Electronics=&cName=HomeTheater&Audio=&sName=Accessories&psid=FROOGLE&aff=Y&sid=KAx20061023x272xTier3
Nov 11, 2009 | Hitachi P42A202 42 in. Plasma TV
Digital TV Ready?
I believe you need a converter box. Im pretty sure this unit only has a NTSC Tuner. Recieving HD would be via Componet Inputs or DVI. If a HDMI Input is available you could use it too but I think it only has a DVI connector.
Hope this helps,
Skyassoc
Jun 19, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Hitachi 51SWX20B is this TV HD ready?
In answer to your question, you have an HD TV Monitor, which means that your television is capable of viewing high definition, but does not have an HD tuner. You will need a separate tuner or in the case of cable, a HD cable box. These are the only options that you have for viewing high definition channels.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs UP) If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
May 24, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Digital signal hookup and compatability
the tv will be hd through the dvi port you can purchase a converter at most shops the you plug the hd freview sat and it will work if the tv has freview built in then it will still work when the switch over happens
Jan 17, 2009 | Hitachi 46F510 46" Projection HDTV
Blue Ray Hookup
i have a ps3 hooked up to mine and the blue ray works very good connected using hdmi cable, converters work good also just purchased Hisense HDTV Tuner for mine
Dec 30, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Hitachi 51SWX20B 51" Rear Projection Television Logo
183 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
