Question about Samsung WF206ANS Front Load Washer
I keep getting a nf error message. what is this
My samsung front load washer keeps giving a nf error message. model # WF206ANS/XAA what is this and how can I fix it. can't find my manual because we just moved!
Posted by redhead357 on
Anonymous
  • 232 Answers
Water fill valve screens may be plugged filling too slow or valve may be bad or is one of the hoses turned off
Posted on Dec 31, 2009
Nf code and donnot continue to next cycle
Samsung Washer Error Code NF (Fixed ...
www.appliancerepairlesson.com/.../samsung-washer-error-code-nf-fixed/
Jan 11, 2014 - What does the error code NF mean on a Samsung washer? ... You can set the washer to any cycle and test each solenoid for proper voltage. ... Next would be to check the screens on the back where the water hoses connect. ..... Hi, you don'thave any power to the water valve wires when it should be filling?
Dec 15, 2015 | Frigidaire Affinity ATF7000E Front Load...
I get the nf halfway through the cycle. ALWAYS with 26 minutes remaining after opening and shutting the door several times and can get it to resume the cycle.
SAMSUNG WF331ANW/XAA TROUBLE SHOOTING GUIDE ...
www.manualslib.com > ... > Washer > WF331ANW/XAA
View and Download Samsung WF331ANW/XAA Trouble Shooting Guide technical information online. 3.7 cu. ft. High Efficiency VRT Steam Front Load Washer (Neat White). ... DC68-02834A-03_EN. 2011-09-28. 4:00:29. Previous page ... SamsungWF337AAG · Samsung WF338AAB · Samsung WF331ANR/XAA · Samsung ...
Support - Washers WF431ABP/XAA ' Samsung Washers ...
www.samsung.com > ... > Washers
Samsung Electronics
Dec 08, 2015 | Samsung WF338AAB 4.0 cu. ft. Front Load...
Error message of
That means overflow. There is too much water in the drum. Turn the unit off and it should drain. If not then it might be a sensor that is bad.
Dec 03, 2013 | Samsung WF206ANS Front Load Washer
FRONT LOAD WASHER samsung model WF338AAW/xaa
you need to sort this part out level sensor located near to the door switch and main board.
samsung boardpng-vn1wiordb5lxotmqu1or3lil-1-4.png wiring will be similar to this. might have a blocked air feed from the drum don't blow into the sensor take the clear pipe off and blow down that to make sure its not blocked, washing powered and stuff can block the line.
Jan 13, 2018 | Washing Machines
please see the cause and proceed to test the water inlet valve can be defective and replace it.use the common sense,see the diagram
God bless you
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Sep 19, 2012 | Washing Machines
I have a wf206ans machine and today i had error code that looks like (be) or (he) i cant find the manual for this machine .this code appears on all cycles for the machine washing or spinning only . any...
The manual for the WF206ANS is available here: http://downloadcenter.samsung.com/content/UM/200701/20070131100335625_WF317AA_XAA_02291A.pdf . The table with the code list is on page 22 of the pdf (page E-3). A bE error is a motor speed sensor error. If the code reappears when you restart the cycle, then the washer needs service. For other codes or for service, call 1-800-726-7864 (1-800-SAMSUNG).
I hope this helps.
Mar 27, 2011 | Samsung WF206ANS Front Load Washer
The code nf keeps coming up what does that stand for
NF(No Fill) code indicates that the washer is not getting enough water supply. Check if wwater supply is turned On and water is coming through the pipe. Then the fill valave can be clogged. t can become clogged with sediment over time
Stop the water supply and then remove the hose and then check for any clogs and if they are fine then in your case most probably your fill valve must have gone bad for this problem.Replacing it must solve the issue.
Jan 14, 2011 | Samsung WF337AA Front Load Washer
Not spinning or draining Samsung front load wf206ans/xac
Won't spin if it hasn't drained. Most probably a blocked/jammed pump impellor. Manually drain it from the lower drain pump (by side tube if that model has one, or slowly into a shallow pan. Remove cap completely & check for things jamming pump.
Dec 12, 2009 | Samsung WF206ANS Front Load Washer
Samsung WF206ANS Front Load Washer Logo
2,832 people viewed this question
Top Samsung Washing Machines Experts
Eric Rotmil
Eric Rotmil
Marvin
Marvin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
