Food Mixers Logo
Posted on Dec 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PLEASE HOW TO CHANGE OIL OF A HOBART MIXER H-600 C Cooper Lebanon PA
Anonymous
Level 2:
New Friend:
  • Expert 110 Answers
  • Posted on Jan 09, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
110
Questions
0
Helped
71446
Points
194
Underneath trans. you will find a drain plug remove, drain oil,replace plug ck the sight glass @ this time if not clear would recommend replacing glass remove top cover where the front cover screw theaded into remove that is your fill hole. add new oil till you hit level line in sight glass,reassemble
1helpful
1helpful
HELLO, My name is Timothy and I got a motor repaired for the Hobart H 600 stand mixer and I need to ask one Question. What is the gear oil that this model takes as I lost some of the gear oil during...
Planetary takes six ounces 150 weight gear oil if completely drained (i.e. Exxon Spartan EP 150 or equivalent). Transmission uses one gallon 460 weight (yeah, 460 weight!) gear oil (Exxon Spartan EP 460 or equivalent).
About how many time you must change the oil.
For most applications once every two to three years should be fine.
4helpful
2answers
How to change oil in 20 quart hobart mixer and the type of oil
on a a200 there is no oil. this mixer requiers grease. if mixer is leaking oil it is because the grease is broken down .you have to pull tpo cover off mixer remove trans. parts clean out old grease clean all trans. parts reassemble put top cover back on .then make sure mixer runs in all 3-speeds before putting 1.5 cans of -47grease back in grease can be bought @any hobart office
What type of oil does a Hobart 60 quart mixer use?
a H-600 takes part#102973-71, thehl600 takesthe same just less. dont for get to vote tks. monomoy
3helpful
How do you change the oil in a hobart h 600-dt dough mixer & what type of oil do you use ?
there is an oil case drain pulg under the top by the clutch, you can drain the motor housing through there, \
i have used 5w30 in a pinch
but it would be better if you ordered hobart oil from the website
its cheap but very very good
46helpful
3answers
Oil change for hobart h-600 mixer
Needed to know which part to open up to add or change oil on Hobart Mixer h-600
7helpful
2answers
What type of oil is used in hobart-h600
hi / I have to chang hobart mixer h600t oil seal on the end of dough hook , but not sure how ? please let me know if any one
knows about that
Jun 23, 2008 • Food Mixers
Top Hobart Food Mixers Experts
vince
NOEL
NOEL
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
