Televison & Video Logo
Question about RCA Universal Remote Control
RCA remote only controls volume.
RCA universal remote RCU403 only controls the volume on my Panasonic TV/VCR combo unit. I just received this used TV from a friend, and the remote is lost. When I programmed this remote, it will only control volume.
Posted by rde54 on
Anonymous
    New Friend:
  • 76 Answers
Ask a tv technician for the kind of universal remote which might best fit your tv common control...
Posted on Dec 31, 2009
3answers
I have two RCA remotes. 1st RCU 310 5538P. 2nd RCU 400 2420BB.
Remote Control Support - RCA ' Made for Moments
www.rca.com/support-remotes
RCARemote Control Support. Select your Type of Remote. Remote Code Finder ...RemoteProgramming. Cable/Satellite Receiver Codes. Select Your Provider.
RCA Universal Remote Control- Target Programming ...
www.thompsontv.com/rcarc.html
RCA Universal Remote Control-Programming Codes. ... Universal Remote. The remotemay already be set up to operate your brand of TV, VCR, or Cable Box.
Program an RCA Universal Remote Without a "Code Search ...
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
It's not working what can I do to program one for all controller to rca tv
HI,
The One For All 3 Device Universal Remote Control is preprogrammed at the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola cable box. To control devices other than the default brands, perform the following steps; otherwise skip this section:
HOW TO PROGRAM
1.Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insert media (e.g., cassette or disc)
NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step.
( CHECK THE BELLOW ADDED LINK TO FIND THE CODE )
2.On the remote control, press a device key once (i.e., DVD/VCR, CBL/SAT, or TV).
NOTE: To program control of a VCR, PVR (or DVR), TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCRonce. After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions.
NOTE: To program control of a DVD Player, DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD/VCRonce. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SATonce.
3. Press and hold SET until the LED (red light) blinks twice, then release SET
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly, the LED will blink twice.
NOTE: If the LEDdid not blink twice, repeat steps 2 through 4 and enter the same code again.
5.Aim the remote control at the device and press POWER once. The device should turn off.
If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works. If it still doesn't work, try Searching For next code.
NOTE: If the device does not have a POWER key, press PLAY
6. Repeat steps 1 through 5 for each device you want to control. For future reference, write down each working device code following.
Electronics Equipment Repair Center ONE FOR ALL URC3021 UNIVERSAL REMOTE...
I was wondering some codes for a RCA tv/ vcr combo
have a old rca television with a build in vcr. connectec a cable box remote works only for volume and channel but power button does not work, with remote was set and stop working call cable company and was told to contact rca to recieve codes for television
8helpful
2answers
Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
  1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
    www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
  2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
    www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
  3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
3helpful
I have a panasonic omnivision vcr/tv combo and i had to buy a universal remote; i have an RCA rcr312w universal remote, but i need the code in order to program the television; what is the code?
I have the same tv/vcr combo and according to my Advent unversal remote chart Panasonic code =
one of : 1003, 1054, 1062, 1109, 1170 or 1248
According to my Phillips universal remote chart = 416, 937
Hope this can help you
Phillips magnavox tv/vcr combo need codes to program remote
most universal remote controls will not operate the combo type units. Contact www.remotes.com for a repoacement remote.
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
