Re: Sony rear projection tv will no longer focus. tried...
Convergence issue. The sony type 1 convergence kit from www.tvrepairworld.com should repair that issue. The kit contains the parts and CD with instructions.
Adjust focus block, then adjust each of 3 lenses. loosen w/ thumbscrew, then turn cylinder to focus onto screen. Focus each by covering the others w/ typing paper, then tighten.
Try using the Flash Focus to/or manually try to dial in the convergence. If you are unable to focus the TV using its convergence adjustment it's time to call the TV repair guy. Figure on between $250.00 and $400.00 USD.
with this type of tv, you can be almost certain that something has gone wrong with the lamp or the cooling system for the lamp. the cost associated with these kinds of fixes are usually more than the unit is worth. The life span on rear projection TV's is not all that good,5-10 years. some last longer. but for most this is a good estimate. this tv has an auto focus feature that might help. also if this TV has a SD slot for upgrades, give it a try as well.
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks! See link for more detail http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
hello do these checks first Adjust the Picture setting in the Video menu (see page 49). ❏ Adjust the Brightness setting in the Video menu (see page 49). ❏ Check antenna/cable connections. ❏ Adjust the convergence again using FLASH FOCUS (see “Adjusting the Convergence Automatically – FLASH FOCUS™ –” on page 33). if this don't work get back to me and we'll try somethink else thanks
Its a Common Problem with Projection Tv's ~ If your flash focus is not correcting the problem, And It can Not be Adjusted in your service menu: under Manual Convergence, your IC chips and maybe a few resistoirs may have failed and need to be replaced!... onegeo
