Makita JR3050T Recipro Saw  9 Amp Logo
Posted on Dec 30, 2009
JR3050T blade lock lever is stuck
The blade lock lever is stuck in the "unlock" or open position. Is there a way to fix this (without voiding the warranty or having to take it in for service? I just purchased this 2 days ago and nit hasn't even seen action yet. The blade lock system worked well for the 30 minutes i had it before the spring lever became stuck!Any help would be appreciated!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3562
Points
I lossened the screw on the guard and the lock returned to the lock position and thanthe screw that is the bib screw
Anonymous
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Feb 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
33876
Points
13
Put a blade in it.
This will release the locked open feature.
2helpful
2answers
New Ignition Barrel. Same prob. Key will not turn to off position
It sounds like you need to replace the (electric)ignition switch. When they go bad you will usually hear a crunch sound, they can be so bad as to overheat and cause other issues.
There's probably nothing wrong with the OEM key/barrel.
Lever stuck in unlocked position
Checout utube or pinterest...lotta info there
2answers
I own a Dewalt dw304p reciprocating saw and I cannot put in a blade because the blade clamp release lever is stuck in the up position. What can I do to fix this?
I had this problem when I first purchased my saws-all from Home Depot. There is a screw at the base of the blade housing. Loosen it up a little and the blade lock should pop back into the down position.c3291d70-d20e-4116-8972-743d243e731a.jpg
Jul 13, 2018 • Dewalt Saws
2answers
My lever to my Dewalt xrp reciprocating saw some how got stuck in the lock position and i have no idea how to remove the lever to fix it
Often when these recip saws get jammed around the blade or lever it is usually due to sawdust or grit that has worked it's way into the mechanism or else the mechanism has actually broken. After a full day of work I often have trouble getting blades removed.
First try spraying the whole mechanism with silicone lubricant and let it soak in. Try tapping as forcefully as you can around the mechanism without breaking anything. If the lever and mechanism isn't actually snapped off somewhere, this usually does the trick.
Dec 02, 2010 • Garden
Both door locks do not work properly. I can only open the drivers side door from the inside. And the passengers side door will not open at all. This is on a 1999 Ford Explorer Sport.
Do any of the door handles inside or out feel sloppy (when you pull on them does it feel like there is nothing connected to them)?
If so that the levers on the latches are probably rusted up and sticking. Say for example the outside door handle lever that is attached to the door latch is stuck half way in the open position it will not allow the door lock mechanism to lock or unlock. The door will still latch and stay closed because the lever will not be stuck far enough to release the latch mechanism from hold on to the striker.
I have had pretty good luck removing the door latch (the part that actually holds the door closed) and soaking in penetrating lube and working all the levers until they move freely.
As far as the door that doesn't open I suspect it is stuck in the lock position and one of the handle mechanisms is in the partial up position. Again the symptom would be a sloppy door handle. That lever will need to be put back in its normal resting position before the door can be unlocked. This can be done with a slim jim. Once you have the door panel apart on the door that still opens you will be able to see the parts you need to move. You can then use that knowledge to move those parts on the other door that doesn't open.
If you don't have any experience with a lockout kit (i suspect most people do not) that that's the best way I can describe how you can do this yourself.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
1helpful
3answers
My door on my n01 grand am gt 2 door will not close. the thing in the door is like stuck locked? what can i do
Manually push the lock button into the UNLOCK position. Now HOLD the OUTSIDE DOOR HANDLE in the OPEN position while at the same time, moving the DOOR LATCH into the open position. Hope this helps
9helpful
4answers
Lexmark X83 "Unlock Scanner" error
I had the same problem and the solution is this: There is a red lever switch by the power chord on the scanner/printer. Above this red lever switch is the drawing of a lock in the "locked" position and at the bottom this red lever switch is the drawing of a lock in the "opened (unlock)" position. The lever on the red switch should point to the "opened" lock symbol (unlock). It the switch lever is pointing to the "locked" position of the lock symbol, flip it to the "opened" position and recycle power on the scanner by removing the power chord for a 30 seconds. If the lever is pointing to the "unlock" lock symbol, flip it to the "locked" position and then back to the "unlocked" position and recycle power. Good luck!
Top Makita Saws Experts
Sean Wright
Sean Wright
john h
Are you a Makita Saw Expert? Answer questions, earn points and help others
