Question about Motorola Mobility Bluetooth Headset-Silver/Black Headset
I am trying to pair a motorola bluetooth and an iphone. Will that work, if so how?
Posted by hollie0721 on
Anonymous
    New Friend:
Yep it will work, but you cant have Auto Answer facility in iphone.....Hav Paired the same with my motorola headset
Posted on Feb 03, 2010
4 Related Answers
Anonymous
SOURCE: pairing my bluetooth to my phone
The Passkey for any bluetooth is 0000 so if you put that in it should work.
Posted on Jan 03, 2008
Anonymous
SOURCE: Motorola H505 Bluetooth Pairing - pass code
Use 4 zero's. That worked for me.
Posted on Apr 09, 2009
Anonymous
  • 3 Answers
SOURCE: How to pair Motorola H12 with iphone?
I just figured it out myself!!
here is how:
1.) press your home screen button at the bottom of your iphone
2.) open settings
3.) go into your general settings (same gear picture as home page)
4.) touch to open bluetooth
5.) turn on your H12 headset and place close to your iphone
6.) turn on bluethooth on iphone and it will automatically find the headset
7.) touch the motorola H12 button and it will enable the connection
Posted on Jul 08, 2009
Anonymous
SOURCE: How can I pair the anycom ARIS-21 bluetooth with
Just push the button for a long time until the led is not flashing but the colors of the led are changing red and green. I connected it to my laptop and my phone too.
Posted on Sep 27, 2010
I lost pairing to from my moto tx550 bluetooth speakerphone to my iPhone and cannot get it back
Try pairing again.
TX550 Bond Pair
Be sure Bluetootis enable on your iPhone when you search for your tx550.
Mark
Motorola Support
Mar 03, 2015 | Motorola Mobility 89589N - SonicRider...
How do a pair a Motorola TX550 to a 5c iphone
Abel
Ensure you turn on Bluetooth on your iPhone 5c then follow instructions here. TX550 Bond Pair
Mark
Motorola Support
Jan 06, 2015 | Motorola Radio Communications
I need guidance in pairing my apple 4g iphone to my motorola T215 Bluetooth
Ensure your t215 is not connected to another device. Then turn it on and let it start pairing mode. Once on then enable bluetooth on iPhone and search for the t215. It should ask for code. 0000
once paired and connected you can usit to make calls.
Mark
Motorola Support
Jun 22, 2014 | Motorola Mobility T215 Car Hands- Kit -...
I am trying to connect my T305 portable bluetooth car speaker phone to work with my iPhone 3G, but I keep getting Motorola T305 not paired What should I do?
Hold the power button in on the speaker system until the indicator light turns purple. Have your Iphone scan for bluetooth devices and select the T305. The first time it connects it will ask for a security key which should be 0000. If that doesn't work try 1234 as well.
At that point it should pair successfully and you should be good to go.
Please leave feedback if you found this helpful. Thanks.
Mar 25, 2011 | Motorola Mobility Bluetooth Hands-Free...
Need instructions for connecting ear piece to iphone 4
Hi,to complete the look of a tech-savvy, iPhone-using individual, you must have a Bluetooth headset to accompany it. You can pair any Bluetooth headset with an iPhone. The Motorola HS850 is no exception to this. Both Motorola and Apple's Bluetooth set-up process is fast, so you'll be talking with people through your new Bluetooth on your iPhone in a matter of minutes.
Instructions
Charge the Motorola HS850 headset fully before attempting to pair. Usually, it takes two to three hours to charge the headset.
Press and hold the "Call" button (has a phone icon on it) on the headset for six to 10 seconds. The outside LED light will turn on indicating that the phone is in pairing mode.
Choose "Settings" on the iPhone homescreen.
Select "General," then "Bluetooth."
Select to turn Bluetooth on.
Wait for the phone to search for in-range devices.
Select theMotorola HS850 from the list of devices.
Enter the headset passkey to complete the pairing. By default this is "0000."
Have a nice day..
Feb 23, 2011 | Motorola Mobility HS850 Consumer Headset
I'm trying to pair a motorola bluetooth device with my iPhone 3G with no luck and from what I've read, this is a problem. Help would be appreciated.
Motorola aren't made to pair with the iPhone, its most likely just down to software difference, so its not a problem with the Motorola device or the iPhone, they just aren't compatible, if you visit the Apple website it will have lists of bluetooth devices, not all Apple, that work with the iPhone.
Dec 24, 2010 | Apple iPhone 3G
When i try to turn on the bluetooth function on my 3gs it remains in the search mode- (the circle of death) forever and doesnt pair with my motorola H710! Help!!
it wont pair whatever you do. even if you install a photoshare app on your iphone, it still wont be able to transfer files to and from your iphone. the iphone's bluetooth only works with other iphones/ipod touch.
Aug 03, 2010 | Apple iPhone 3G
Iphone and headsets
Yes, you can pair your iPhone with any bluetooth headset. I have used many different Plantronics headsets and all have worked perfectly.
On the iPhone, go to Settings (the gears icon), click GENERAL, then Bluetooth and make sure it's switched to "On". Then, follow the pairing instructions that come with the headset.
Oct 07, 2009 | Motorola Mobility Bluetooth...
My iPhone 3G does not discover my Motorola H500.
Try this link. It solved my issue www.scribd.com/doc/280088/motorola-h500-bluetooth-earpiece-manual. Basically what you need to do is power the earpiece off. Make sure that your IPhone is not currently attempting to discover bluetooth devices (i.e. Bluetooth is OFF). Hold the On button on your earpiece (it has the symbol of a phone on it) for 6-10 seconds. The light on the earpiece remains lit. Now your earpiece is in discovery mode. On your IPhone, go to Settings, General, Bluetooth. Turn Bluetooth ON. Now your phone and your earpiece are both in discovery mode. When you see "Headset" listed, select it and enter the password "0000". Your IPhone is now paired with your H500 headset.
Mar 24, 2009 | Motorola Mobility H500 Wireless Headset
here is how:
2.) open settings
Jan 08, 2009 | Motorola Mobility Motopure H12 Bluetooth...
Motorola Mobility Bluetooth Headset-Silver/Black Headset Logo
156 people viewed this question
Top Motorola Mobility Radio Communications Experts
JonSnell Electronic
JonSnell Electronic
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
