Question about KitchenAid 24 in. KUDS25SH Built-in Dishwasher
MY KITCHEN AID DISHWASHER MODEL #KUDS25SH CHIKD LOCK IS ON AND WONT GET CLEARED. I TRIED HOLDING THE ENERGY SAVER DRY BUTTON FOR FOUR SECONDS AS SAID IN THE TROUBLESHOOTING SECTION BUT DOES NOT CLEAR. PLEASE HELP I CANT AFFORD A NEW DISHWASHE
Posted by candyarlene on
Anonymous
    New Friend:
  • 3 Answers
Try turning off the breaker to the Dishwasher...See if it resets ...Good luck.,..
Posted on Dec 30, 2009
My top drawer of kitchenaid dishwasher lock light is on. I can't get it off?
It's a child lock. To turn off the child lock on a Kitchen Aid dishwasher, locate the Energy Saver/Dry button. Press and hold this button for at least four seconds.
Jun 20, 2016 | KitchenAid Dishwashers
My lock button wont go off
1. Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
May 20, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
KitchenAid dishwasher KUDS25SH - Can't operate because child lock
If holding the "Energy Saver/Dry" button does not solve the control board problem then most probably the control board would have failed and needs to be replaced .
To identify it we need technical expertise in handling the circuit boards and knowledge on usage of multimeter is must.
Apr 05, 2010 | KitchenAid Dishwashers
The child lock is stuck on my kitchenaid superba dishwasher
Apr 03, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
How to unlock the child lock
Most of the dishwasher in this series have an energy saver dry button. Hold this button in for four seconds and it should unlock the child safety lock. Does not work, try again for 30 seconds. Does not work. We have problem. If your model does not have an energy safer button, then type in the model number and you should be able to find the manual online and open the same to find out how to unlock the child safety lock. If all fails then you need an Electronic control board assembly, about $86 for your model, plus shipping from repair clinic.com. If you are at all handy, this is easy repair. Make sure you turn off the breaker or remove the fuse before you attempt any repairs.
Feb 08, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Child lock won't unlock
If the model number is correct, you turn the Child Lock on/off by pressing and holding the "Energy Saver Dry" button for 4 seconds. If your model numbers differs, please post back with the correct information so that I may be able to provide you with better assistance. I hope this helps you.
Nov 26, 2009 | Kitchen Ranges
Kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Sep 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Oct 19, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Child Lock continuously flashing
the solution is to change the electronic control.....cost 110$
Sep 02, 2006 | KitchenAid 24 in. KUDS25SH Built-in...
KitchenAid 24 in. KUDS25SH Built-in Dishwasher Logo
642 people viewed this question
Top KitchenAid Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
