Question about Panasonic PV-DM2792 Triple Play 27 in. TV/VCR/DVD Combo
Looking for code to enter into remote for Panasonic triple-play tv Having trouble getting the comcast dta to work.
Anonymous
    New Friend:
I gave up
Posted on Dec 31, 2009
Program remote for comcast
Check these codes: 11144, 11240, 11331
programmmming TVTV control
The Comcast DTA remote control is preprogrammed at the factory to operate the DTA receiver. The Comcast DTA remote also contains a universal TV library to allow you to control the Power and Volume of your TV.
1. Turn on the TV
NOTE: Please read steps 2 to 4 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2.
2. Press and hold Setup until the Red Light blinks twice, then release Setup.
3. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first.
4. Enter the first five-digit code for your TV. If you perform this procedure correctly, the Red Light will blink twice
NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code.
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code.
Jul 16, 2012 | Olevia 227-S11 27 in. LCD TV
Remote codes for Panasonic MODEL# PV-DF2704
5 digit code for the comcast red button silver remote is 21462 this pertains to Panasonic MODEL# PV-DF2704
Nov 20, 2011 | Panasonic PV-DF2703 Triple Play 27 in....
Looking for the code for Comcast DTA remote for Toshiba 15LV505. The 11343 nor any of the other codes work. The search also is not effective.
the code would have to be looked up through comcast remote, not toshiba. Google the remote and model for tv codes
Dec 31, 2010 | Toshiba 15LV505 LCD TV
Need Comcast DTA remote to control Panasonic TV/VCR combo
Try website 1-800-Remotes Factory original.To buy an exact remote or very close to the original.
Apr 25, 2010 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Need TV codes for using the comcast DTA remote
I just went through this last night with combo, similar model. They tell you to use the power off test to see when you've got it - nothing worked for that. Then I tried the Panasonic codes and used the volume control as a test, which is much more important, and I found the 3rd code worked for that. I figured, close enough for me, and better than nothing.
Sep 09, 2009 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
The manual does not list the actual remote control code
 It will be one of these:
11866, 10054, 10030, 10706, 11990, 11963, 11913, 11904, 11525, 11365, 11198, 10802, 10230, 10187, 10186, 10179
As found in the online manual at::
http://www.comcast.com/DIGITALNOW/Contents/DTARemoteGuide.pdf
I hope this helps
Sep 08, 2009 | Philips Televison & Video
try these codes for broksonic 10236,10463,11911,11938, 10030,11935,11929
Apr 25, 2009 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Dec 24, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Panasonic PV-DM2792 Triple Play 27 in. TV/VCR/DVD Combo Logo
641 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
