Question about Sanyo MM-8300
Phone got wet, need to get sim card out?! Or clean it. Thank you, Mark Coffey
    Scholar:
  • 51 Answers
Hello!
Make sure the phone is completely dry before you turn it back on . Take out the battery and the SIM card and completely dry them off - Especially on the electronic contacts.
Heres a trick: If you have a food dehydrator leave the phone in it for a couple of hours. This will remove the moisture from the phone and the water won't short circuit the phone.
If you have trouble locating your SIM card, it is under your battery and should slide right out with no trouble. If you do have trouble, please comment on the question and we can try something else!
Cheers!
Feedback is appreciated!
Posted on Dec 30, 2009
HOW TO MAKE SURE SIM CARD IS WORKING PUT SIM CARD IN AND DOES NOT REGISTER ON PHONE
Try taking the SIM card out and giving it a clean with a clean cloth that is not wet at all. An alternative is to contact your service provider and ask them for some advice and perhaps send you out another SIM. Is this SIM new?
Oct 13, 2018 | Cell Phones
Nokia n73 offline
Hi first of all after inserting Inserting Sim Card and power on your phone,,a message will prompt you to select "Start up phone without Sim Card" select NO. If there is no any option displays a there might be something wrong with Sim card related components.So try to clean the sim card slot.Otherwise you need to visit mobile repairing shop.Thank you
May 08, 2013 | Nokia N70 Cellular Phone
NOKIA C3 GOT WET NOW WONT READ SIM CARD PHONE LETS YOU START UP WITHOUT SIM
Turn off the phone and pull the battery out. Put a small amount of alcohol on a cotton swab and gently try to clean the sim connectors. Put again your sim card e turn on your phone. After that, if the phone doesn't recognize the card, try with another simcard if possible.
Sep 12, 2012 | Nokia C3-01 TOUCH AND TYPE QUAD BAND 3G...
Insert sim
Remove the SIM and clean it with soft cloth.
Try the SIM on any other Mobile phone.
You can also try another SIM card on this mobile to make sure the phone is working properly.
If another SIM card is working properly that means the SIM card you are currently using may be corrupt. Its easy to replace a SIM then replacing a phone.
Clean both SIM and phone Connectors then try to insert the SIM.
Thank you for using Fixya.
Nov 14, 2009 | Motorola Mobility SLVR L7 Cellular Phone
My phone doesn't read my sim card, what can i do? when i put it in the message indicate: inserte sim card. model Pantech PG-C3 Thank you
1)clean sim card with your finger, then clean sim card holder with a cotton swab. 2)if this fails, go to your local phone shop, and they will switch your number to a new sim card, or inform you that your phone is broken. P.s. do not use lquids for cleaning.
Jun 11, 2009 | Cell Phones
Cant figure out how to open back of phone to put in new battery
First: you need to simply remove the back; then after you remove the back the battery will be there. If it wasnt removed simply remove the battery from the back of the phone without it getting wet. There might be some slight difculty doing this. What you have to do is ; slam the back of you're phone; on you're thigh if you have anyproblems. also place the sim card in behind the battery u will find the sim card slot; . Then place it in the slot facing up wards.
Thank You; :-* Hope it works!
May 02, 2009 | T-Mobile Sidekick II
Sony w580i
try cleaning the sim card holder brass contacts or take it to a mobile service shop and have them fully service it for you to determined whatelse may need to be fix in your phone.
Jul 21, 2008 | Sony Ericsson W200i Cellular Phone
N95 8gb
TRY TO ALIGN YOUR SIM SOCKET
May 26, 2008 | Nokia N95 Cellular Phone
Nokia n80
Have you tried to reflash the software? You may also need to check the SIM EMI Filter, it's a small shiny chip near the sim connector. If the connections under it are not clean (e.g. minerals and oxidations) it will not work.
Feb 13, 2008 | Nokia N80 Cellular Phone
Cell Phones Logo
162 people viewed this question
Top Sanyo Cell Phones Experts
Ekse
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
