Question about GigaFast Ethernet WF719-CAPR Wireless-G 4-port Broadband Router
What is the IP address for WF719CAPR? I am having problems enabling the modem. Please help
Posted by blake99 on
Anonymous
    New Friend:
  • 34 Answers
To get the IP Address for WF719CAPR
1. Connect that device ( a modem? or a router?) to your computer via ethernet cable (Turn on your router or modem)
2. Click "Start"
3. Click "run"
4. Type "cmd" without quotes on the window
5. On the black screen type "ipconfig" without quotes and press enter
6. Check for the "Default Gateway" whatever's in there that's the default IP Address of your (router/modem) or maybe a different IP Address if the ( modem or router ) is not reset to default.
Posted on Dec 30, 2009
Anonymous
  • 3 Answers
If you type in "Finding IP Address" (without quotes) into Ask.com. Your IP adress will show, Copy and Paste into the address bar of your browser, and press enter. If you have to enter your username and password, it might be "admin" for both, mine was, though mine was a D-Link. Then press "Setup" it's quite obvious from there, also I dont know what your router will be, as mine is different from your's.
Rob C
  • 547 Answers
The default address is 192.168.8.1
GigaFast has a good FAQ page here, hopefully it can help you get it enabled.
If this helps, please remember to hit the "thumbs up" for me.
If not, post back with the "add comment" button and I'll do what I can to help.
D LINK DSL-2640B Router's Wireless keeps disconnecting
both modem ip address same please check book the modem and install modem ip different 192.168.1.1 and 2nd 192.168.1.2
Hi Currently i am using internet Type: Broadband provided by Local Cable operator Modem:Motorola SB5101i Connection type: PPPoE [with username/password] Using with: Dell inspiron15 Laptop Location:...
There is a configuration facility included with the modem that you should be able to access to help troubleshoot the connection.
The Cable Modem has three active interfaces, the HFC, the Ethernet and the USB and each
interface has both a MAC and an IP address associated with it. When operating normally it is the
IP address of the HFC interface that is used for diagnostic access to the modem. However the IP
address associated with the Ethernet interface is always available to the client side network,
unless it has been disabled by management command. This means that a PC on the client side
can access the WEB pages within the modem using the reserved address 192.168.100.1. This is
a non-routed address so it cannot be reached from the Internet (routed) side of the network
The SB5100 family of modems contain an internal DHCP server, which is active until the modem
registers with the CMTS. In the case of a problem that prevents the modem from completing its
registration, the modem can still give an IP address to the client PC to enable diagnostics access.
This address is given with a very short lease (around 10 seconds) so that as soon as the
registration does complete the client PC obtains its proper IP address from the core network
DHCP server.
Plycom ip330 phone - works fine when connected directly to Brighthouse modem, however when brighthouse modem connected to belkin router then to phone says - waiting for network to initialize, please help
sounds like your belkin router is not setup as a DHCP server or the DHCP is disabled. The DHCP in the belkin assigns addresses to the internal network, the error "waiting for network to initialize" means that the phone is waiting for an IP address, to which its not getting. When you connect directly to your modem you get an IP from your Internet service provider. I'll bet your internal network is setup using "static" ip addresses, if thats the case you will need to surf into the phones web console and set a static IP address. Or the opposite, enable DHCP in the belkin. hope that clarifies things a little.
Internet connection problem in ubuntu
That depends on the modem and router settings. If you are using cable modem (a box connected to the cable from your internet service provider) without a router, you will need to set your computer to get a IP address automatically and restart the modem. Then you can renew the IP address if necessary. If you are using a router (another box) connected with the modem, then you might want to connect to the router by using the IP address on the same subnet as the internal interface of the router and enable DHCP. Then you can restart the modem and get an IP address for the router (usually you can see a button to click for that on the management page of your router after you open that in your browser, check the manual of your router about details). After that you can reconfigure your computer to use dynamic IP address and then renew IP address or restart. Please don't hesitate to post if you have questions.
1helpful
2answers
How to connect 2nd computer to internet from bsnl type2 modem modelzxdsl 531b through ethernet cable
Its simple
1. connect a lan cable from ur modem to ethernet switch(For ex: 4-port)
2. Take 2 cables from ur switch ports and connect it to ur Pc's
3. Configure DHCP on your modems. So that ur pc's obtain ip address automatically from ur modem.
This is how u connect multiple computers to internet by a single internet connection
Router connection
1. Please check your computer have a static IP address.
2. Please put your computer's IP address shout be automatic.
2answers
Computer will not recognize drivers for ethernet card
Was this all working just fine prior to reinstalling the system on the computer. I want to first rule out any hardware connection problem. When you check the ethernet adaptor in the device manager, does any punctuation mark appear next to it to indicate a driver problem? if not, your problem is not driver -related, but rather settings. If the LAN connection appears in the manage connections or the connection wizard, you may only need to enter the correct settings to make this work. Make sure TCP/IP is enabled for the device, and that DHCP is enabled in the TCP/IP settings. The exception to this is if the modem does not assign an address by DHCP but is instead set for only a static address. If that be the case, you will need to enter a static IP address in the TCP/IP settings. In that case, look for a number on the modem in a xxx.xxx.x format, enter the number in the TCP/IP static IP address but adding 10. If the address is static, you will also need to enter a default gateway, which your ISP should have provided to you, along with the static address
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!.
Ip and proxy error
well, if you know how to setup the ip addresses manually both on your modem / router and on the ps3 i recommend you do that... but bear in mind that your dhcp server (on your modem / router) should prohibit automatic assignment of that same ip address with your ps3... for that you have to specify a range of automatically assignable ip addresses apart from your ps3...
if you have the dmz (demilitarized zone) option on your modem / router, set it up for the ip address of your ps3, which you've setup manually...
example:
router ip: 192.168.2.1
ps3 ip: 192.168.2.10
ip address pool: 192.168.2.100 - 192.168.2.250 (this shpould be manually setup not to interfere with the fixed ip address of the ps3)
dmz host: 192.168.2.10 (ip address of the ps3, which enables "opens" all of the ports for this ip address)
apart from that if you use any proxy servers to connect to the net, you have to specify these in ps3 settings as well...
there are a lot of threads on various forums on how to tweak your network connection to optimize for ps3...
i hope this solves your problem...
3answers
Laptop cant connect wirelessly
Hey Charlie, If you re-installed your operating system you will need to get the wireless modem driver from your dell disk. For some reason they have not included the drivers in the windows software. If you can't find it then you can go on to the Dell site(obviously on another computer) and enter your service tag and get your drivers that way.
I hope this helps
Open Questions:
GigaFast Ethernet WF719-CAPR Wireless-G 4-port Broadband Router Logo
Top GigaFast Ethernet Computers & Internet Experts
k24674
Are you a GigaFast Ethernet Computer and Internet Expert? Answer questions, earn points and help others
