Question about American Standard Colony 2388.012.222 Linen Two-Piece Round Front Toilet
Toilet nonfunctioning after heavy rain
I live in a community that's sewer system is overwhelmed after a heavy rain. this causes my toilet not to flush; however all the other drains in the house work fine. does anyone know what the problem could be; how to fix. what effect would a pressurized toilet have in these circumstances. (toilet is over 30 years old don't know brand)
Posted by e.c. potter on
5 Related Answers
projdoc
jasbo
  • 2239 Answers
SOURCE: toilet wont flush completely. it may take 4 times
there is no air release. the vent must be clogged somewhere. you can take a hose up there and see if it drains all the way or floods over. since the tub drain has a trap and the toilet itself is a trap, there has to bee a good amount of air pressure coming up without a release. i would say an obstruction. possibly at the junction of the main and the vent.
Posted on Nov 13, 2009
djchillsnyc
charlie rodriguez
  • 152 Answers
SOURCE: have to flush 2 or 3 times to empty toilet bowl
hello, this is a standard toilet you will need to inspect the flapper that is the rubber flap that holds the water up in the tank it works when you pull the lever it pulls the chain upward and lets the water flow if this flapper is old it may not stay up long enough for the water to flow. open the tank top and flush the toilet see if this flapper is staying up long enough and giving the tank enough time to empty if not change this rubber flapper its inexpensive part.
if this is not the reason then you need to adjust your water filler valve there should be a small screw on top of the pivoting float arm
if you have to adjust it for the water limit line inside the tank this will be the proper amount of water needed to flush once completely
also check that the chain lenth on the pull lever is not pulling the flapper down quicker than its supposed to,
try this let me know your results
hope it helps
Posted on Dec 15, 2008
buffalonyman
buffalonyman
  • 1865 Answers
SOURCE: I BELIEVE IAM HAVING SOME TYPE OF VACUME ISSUE WITH TOILET
The water in the tank is not filling to the water line, thereby not providing enough water to flush properly. Adjust the float so that the tank fills to the water line
Posted on Apr 27, 2009
Anonymous
  • 760 Answers
SOURCE: sewer oder from toilet replaced wax ring dident
The wax ring would only help if the toilet wasn't sealed to the drain. Is the odor coming up through the toilet? If so then your water level must be low in the bowl, allowing the trap to be open to air. Make sure the little hose from the fill valve is dumping into the overflow. This helps make sure the toilet stays full, when refilling.
Posted on Jul 23, 2010
Andrew Conroy
  • 298 Answers
SOURCE: American Standard Toilet does not flush except on
I would suspect some sort of air lock in the pipe, or just a partial blockage which is slowing the water flow.
You may be able to clear it using a rubber plunger. You need a plunger that has a metal or hard plastic disk fitted above the rubber cup (to prevent the cup turning inside out).
If you have an ordinary plunger without the disk you could probably make one to fit it - perhaps the bottom cut out of a plastic drinks bottle and a hose clip to hold it in place.
You will need to work the plunger quite vigorously up and down in the toilet bowl to force a pulse of water through the system.
Pouring a large bucket full of water down the toilet after plunging may have more impact than just normal flushing. It will also refill the trap.
Posted on Feb 25, 2011
How to empty sewage tank on camper
First, I'm not a camper tech, but I have worked on fixed and portable sewer systems. Get ready as it's a stinker.
* Clogged at toilet means your system is backed up and has dried out at toilet and or sewer system and/or it has not been drained, flushed in a long time. Either way your going to need to find an approved sewage drainage site and drain/flush your system.
with a bit of searching on you tube I found this link that may help you. Though if it does not work then you will probably need proffessional help from a RV sewer repair service.
https://www.youtube.com/watch?v=_zSpW1VwhA4
Aloha, ukeboy57
May 11, 2018 | Cars & Trucks
My toilet flushes, then the water in the bowl drains over 4-5 minutes resulting in sewer gas smells.
Look inside the tank under the lid, it sounds like the flapper that lets the water into the bowl is getting hung up on something when you flush. It could be the flushing lever. This would cause the flapper to stay open letting water to just pour into the open sewer line. It should be a simple fix. Just see what is binding the flapper & make an adjustment.
Dec 02, 2015 | Duravit Starck 2 One-Piece Toilet
Rotten eggs smell
The smell is sewer gas coming back in the house from the sewer or septic tank ether from a dried out water trap in a floor or fixture drain, or from the roof vent, or a hole or separation in pipe or fitting. Like wax ring under toilet. First pore water down every drain to fill any trap that might have gone dry, then flush toilet or run washer or drain bath tub.This will displace gas in pipe and will cause the smell to increases if there is no smell then the problem is fixed if not check roof vent it may need a charcoal filter on top, There is no water trap on air vent on roof and is an open hole to the sewer or septic, The heating system in the winter or AC in summer will draw the gas inside from the vent.If it is the vent you should be able to smell it from outside. If all tests fails You will need to have a smoke test done. A smoker is set up outside and the line is filled with smoke and will show where gas is coming from. Also it might be a good ideal to check all gas fittings in case it is a gas leak.
Jun 15, 2014 | Plumbing
Anyone can suggest me some sewer tank maintenance tips?
I think you'd avoid poring detergent water into your sewer tank and mustn't use hard cleaner to clean your toilets as it will kill all the bacteria in our sewer tanks or never flush plastic items.By following these tips you can increase the life of your septic tank.http://www.ps2i.biz/plumbing-services
May 23, 2013 | Washing Machines
Sewer smell drain
are there any floor drains in the room and an unused bathtub or shower? if so the water may have evaporated from the trap and allow the sewer gas smell. try pouring water into all the drains and see if it is still happening. more elaborate problem may be a broken vent stack in a wall.
Apr 23, 2013 | Kohler Home
Sewer gas smell in bathroom.
Sounds like you have an intermittently blocked vent pipe (the one that goes out through your roof). If there is gas pressure in the downstream sewer line and it can't get up through the vent, it could bubble up through your toilet or sinks. I would get up on the roof with a few jugs of powerful drain cleaner and dump them into your vents. You might also run a few dozen gallons of water down those vents after the drain cleaner has had time to work.
Oct 05, 2012 | Plumbing
My neorest 500 smells we have had it for 4 years. I am wondering what can be done. we love the toilet.
Smells usually come from the tank and not the bowl.
Buy tank deodorizer from local store located near toilet brushes.
http://secure.willert.com/images/bf_wire.jpg
Deodorizer hangs inside tank. make sure it reaches the water.
You can also drain and clean the tank using CLR calcium lime and rust remover.
The CLR and gunk are fine for flushing away as long as the gunk doesn't clog the flush holes that let water flow into bowl.
http://www.fixya.com/support/r6633961-toilet_doesnt_flush_water_just_spins
Sewer line can also cause of odor.
If the toilet bowl is not full of water, or if nearby drain is not filled with water, or if toilet is not sealed tight against floor, or if toilet appears to have dampness visible around base, or if a vent pipe terminates behind a wall instead of on the roof: these things can cause sewer air to enter room.
Jul 28, 2011 | Toto - Toilet - One-piece - Neorest 500 -...
Toilet wont flush completely. it may take 4 times or more to flush solids. i at first thought this was related to heavy rains we had been receiving in the area over a period of about 4 months. 2 days...
Nov 09, 2009 | Eljer 091-2190-43 Platinum Patriot...
American Standard Colony 2388.012.222 Linen Two-Piece Round Front Toilet Logo
1,111 people viewed this question
Top American Standard Home Experts
Mike
john h
Bill Johnson
Are you an American Standard Home Expert? Answer questions, earn points and help others
