Samsung LN-T4071F 40 in. LCD HDTV Logo
Anonymous Posted on Dec 30, 2009
Samsung LN-T4071F WASHED OUT ON LEFT SIDE WITH LINES GOING THRU SCREEN AND PICTURE FLICKERS
Anonymous
Level 2:
Champion:
  • Expert 217 Answers
  • Posted on Dec 30, 2009
Anonymous
Expert
Level 2:
Champion:
Answers
217
Questions
Helped
84228
Points
262
CHECK LVDS CABLE FIRST, TAKE IT OUT OF THE T-CON BOARD FIRST AND RESEAT IT, THEN TAKE IT OUT OF THE MAIN BOARD SECOND, COULD GET LUCKY AND FIX IT, OTHER WISE THE SCREEN IS PROBABLY BAD
Picture jumps
Sounds like a fault with the connection to its T'Con board to display panel. Check for any loose contact at the both ends of connection sockets to LVDS cable. (Low Voltage Differential Signaling) {that involves transferring a signal on a wire and its opposite over a second wire to allow the receiver to reconstruct the signal by difference}. Re-seat all the cables that comes to and goes from the T'Con board once, and check. Contact any service technician. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. http://electronicshelponline.blogspot.com/
Samsung LN-T4071F picture starts clear, then gets grainy as the TV stay on.
I have samsung TV 40 inches flat screen comes on the picture ok but within 10 minutes the picture goes black and white
I was moving my samsung 40 ln-t4071f and cracked the screen. Can i buy one somewhere and could i replace it myself?
To replace the screen is going to cost about at least $500.00.
I will try to sell the tv as is for parts. You can probably get about $100.00 . Thats how much I buy them for.
It would be too costly to fix! I recommend giving the set to your local waste management program.
3 horizontal lines across screen and triple shadow on left side
its a LCD connectors. re-connect it properly. some loose connection.
TV won't turn off
Problem solved. I opened the configuration menu, went to Setup, More, Light Effect, changed setting from "Always" to "In Watching TV".
We have a Samsun LN-T4071F LCD TV. The screen is all white and colored vertical lines. We disconnect the HDMI cable from the Dish box and the screen stays that way. We turn the TV off for a couple hours...
Do you have warranty on this unit?If warranty available contact servicer.
From your description problem is in the Digital board.
Replace digital baord.
Dont forget to Rate!
Good Luck
Dals123
Samsung LN-T4065F Dotted lines across screen
tell the idiots where u bought this tv from and demaand a more expensive and better tv on their bill
NO sound on HDMI3 port and when playing Blu-Ray DVD's the screen is pink
Go to the samsung website, and find out how to upgrade the firmware for your TV. You will probably need a portable usb memory stick to do so (if your TV is equipped with one). HDMI is an evolving technology, and firmware upgrades can resolve many of these quirky issues.
Here's a possibility from http://www.samsung.com/us/support/faqs/supportFaqList.do?group=&type=&subtype=&model_nm=LN-S4696D&dType=D&mType=UM&vType=R&prd_ia_cd=02010100&acc_ia_fl=&disp_nm=LN-S4696D
Which Samsung LCD TVs Have The HDMI 1.3 Interface? spacer.gif Of the LN-T series Samsung LCD TVs, those models whose last two digits are 61, 65, 66, 69, 71, or 81 (for example, LN-T4071F or LN-T466F) have the HDMI 1.3 interface.
Samsung LCD TVs with HDMI 1.3 interfaces also have HDMI-CEC (HDMI - Consumer Electronics Control). For information about CEC, click HERE.
For information about individual Samsung LCD TVs with HDMI 1.3 interfaces and HDMI-CEC, click HERE. When the Samsung LCD TV web page appears, select the TV model you want information about by clicking the drop down list under Product Finder on the left side of the page.
Though other series of Samsung LCD TVs (LN-R, LN-S, etc.) have HDMI connections, none have models with the HDMI 1.3 interface.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
