Question about Hawking 802.11g Wireless-G Range Extender
Hawking Extender- Connected to WiFi but cannot access Internet
My iPod recognizes the new network established by the Hawking Extender, and I've entered the correct password and logged in with no errors, and the iPod's WiFi indicator clearly indicates that I'm connected. However, I'm unable to access the Internet.
Hawking Extender Model: HWREG1
Router: Linksys
Thanks in advance to anyone who might be able to help.
  • 2 more comments
  • Anonymous Jan 01, 2010
    Thanks for getting back with me. Before I try your proposed solution, I want to ask a couple of quick questions:
    1. My iPod can definitely connect to the Internet, if I'm closer to the Linksys router and choose our main network as the connection to use; it's just when I try to select the HawkingExtender network (or have it self-select that, when I get too far from the router), that it doesn't connect to the Internet. Sorry I didn't make that clear. So with that in mind, is your first series of steps necessary?
    2. If so, Is turning off the security on the Linksys router just a matter of unchecking the 3 options I currently have checked ("Block Anonymous Internet Requests; Filter Multicast; Filter IDENT(Port113)"), and clicking Save Settings?
    3. If not, any other ideas?
    Thanks much!
  • Anonymous Jan 02, 2010
    Thanks for your post. The Internet connection is definitely working, as I'm able to access the Internet from a) other computers on the primary network, and b) the iPod, on the primary network. It's just when I try to use the network connection provided via the Hawkings Extender device that I can't access the Internet. The iPod indicates a connection to the network (a strong connection, at that), but no Internet application will go through. Any other ideas?
    I guess I'm confused - because that's exactly why we got the Hawking Extender - to extend the range of our wireless network within the house. It should be able to connect to the Extender, as if it's connecting to the Linksys router, and we should be able to access the Internet from the iPod (or any other wireless computer/device) via the Hawking connection. Right? Or am I missing something?
    It's actually not connected to anything (other than power). That's how it works. You connect it to the router with a network cable, configure it, then disconnect it and place it somewhere else in the house. It's designed to wirelessly extend the wireless network beyond its normal range. So it's no longer connected to either the cable modem or the router. Any other ideas?
John White
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 117 Answers
Same thing happened to us! I researched and documented a solution at: http://hwren1.blogspot.com/ (Hope this helps you.)
Posted on Aug 08, 2015
Jazz Boyce
  • 728 Answers
Check your internet connection on another device or computer and see if it is giving you the same problem as the internet connection may not be working. If it still is not working, if you have a modem, take the cable that is running from the modem to the router and plug it into the computer and see if you can connect to the internet that way. If you can, then try resetting the router and troubleshotting it for other problems that could be causing it. If it does not connect, the consult your internet provider about your connection.
Posted on Jan 01, 2010
  • Jazz Boyce
    Jazz Boyce Jan 02, 2010
    Well the problem is the range. When you get too far away from the router, the ipod tries to connect at first and it says it is a good signal, but since you are far away from the actual router, the internet breaks up and you will get limited to no acess on that connection. Glad I could help!
  • Jazz Boyce
    Can you tell me where/which cable you have the Hawking Extender connected to as it being in the wrong place could mean that it is not getting the proper internet connection. It may have to be hooked up to the internet cable first before the router if it already is not.
Deborah Brown
  • 323 Answers
First think I always do is Reset Linksys Router and disconnect extender. Then turn off all security on router. Do soft reset on ipod. leave extender off and see if you can connect to the linksys. If you can then plug in extender (still with security off) then see if ipod connects to extender.
you might have to soft reset ipod again once you connect the extender.
if that works. reset security. Let me know how that goes.
  • Deborah Brown
    Deborah Brown Jan 02, 2010
    Also found this information.
    you need to change the IP address of your setup computer to be in the
    subnet of the (fixed) initial address of the Extender so you can talk
    to it over your browser, configure it with the target SSID and a new
    (fixed) IP address in the subnet of the desired Access Point, and then
    restore your DHCP or original computer IP address. If that's all
    gibberish to you, you might be in for problems. If you follow the
    instructions VERY carefully you will still succeed, but if anything
    goes wrong you could get stuck.
    One other thing. I have had issues with the ipod touch working with a wireless N linksys router and to turn the security off on your router sign in to it via your browser and go to the wireless section and disable it. then apply. then reset extender to pick up on the changes.
    let me know how that goes.
How to set up netgear ex6100 wifi range extender
Overview:
This article describes how to set up a NETGEAR EX6100 in Extender Mode
The extender connects wirelessly to your existing WiFi network, and then it creates a new WiFi extended network and links the two WiFi networks.
Symptoms:
Cannot connect to extender
Extender broadcasting EX6100_NETGEAR_2GEXT
Extender broadcasting EX6100_NETGEAR_5GEXT
Extender cannot access Internet or network
Process:
1. Place your extender in the same room as your WiFi router.
2. Plug the extender into an electric outlet and wait one minute.The PowerLED lights green.
If the Power LED does not light, press the Power button on the side.
3. Make sure that the mode switch on the extender is set to Extender.
4. Use a WiFi network utility on a computer or mobile device to find and connect to the EX6100_NETGEAR_2GEXT or EX6100_NETGEAR_5GEXT (SSID) WiFi network.
Note: EX6100_NETGEAR_2GEXT and EX6100_NETGEAR_5GEXT are the default name of your extender's wireless networks, and by default it is unsecured. If you changed the wireless name or security in the past, connect to the new name or enter the passphrase when prompted. EX6100_NETGEAR_5GEXT is only visible if your wireless adapter is 5 GHz capable.
After the wireless connection with the computer or mobile device is established, the Client Link LED lights solid green.
5. Open a web browser window from the same computer or mobile device.The browser takes you directly to NETGEAR genie Smart Setup.
Note: If you are not automatically directed to NETGEAR genie, launch an Internet browser and type www.mywifiext.net in the address field of the browser. Enter admin for the user name and password for the password.
6. Select a 2.4GHz WiFi network to extend and click the Continue button.
7. Type the network passphrase (also called password or security key) in the Passphrase field and click the Continue button.
8. Repeat steps 6 and 7 to select a 5GHz WiFi network.
Note: If your router does not support the 5GHz band, click the Skip button.
9. Select Private Network(home network) or Public Network radio button, and click Continue.
Note: Selecting Public Network will enable NAT and DHCP on the EX6100. For more info on NAT refer to: What is NAT (Network Address Translation)?
10. Type the name (SSID) for your WiFi extended network in the 2.4GHz and 5GHz Network Name (SSID) field and click the Continue button.
Note: You can use the same security settings as your existing network by selecting the Use the same security mode check box.
The WiFi extended network settings are applied.
11. Use a WiFi network manager on a mobile device or computer to connect to the extenders newly created WiFi network.
12. Click on the check box and click on Continue to finalize the installation.
13. Unplug the extender and move it to a new location closer to the area with a poor WiFi signal.
Note: The location you choose must be within the range of your existing WiFi router network.
14. Plug the extender into an electrical outlet and wait one minute. The Power LED lights green. Connect to the extender network and enjoy the extended Wifi network.
May 02, 2014 | Computers & Internet
Hwern1 hi gain wireless 300n range extender
what issue are you facing? its not connecting to your existing wifi network ? let me know if you want me to call you if u r in US
Dec 06, 2013 | Hawking HWREN1 Hi-Gain Wireless-300N Range...
Got a Netgear wifi extender but my current password won't work to access the new_ext network.......don't know what to do!
You need a new password to access the new wi-fi extender, you cannot use the existing router password.
Oct 20, 2013 | NetGear Universal WiFi Range Extender...
How do I connect to Internet?
I will help you to connect to internet from your iPod through WiFi.
Goto Settings-->WiFi ON-->it will search for the available accessible networks-->Tap the desired WiFi network-->your iPod is connected to internet.You can confirm this with a WiFi symbol e9083285-5bde-4821-8d34-3573b467f1f4.jpg in your status bar.
You can use Scanmyspeed.com to get the speed of your internet connection.
Sep 08, 2013 | Apple iPod touch
Mywifiext net
Have you first established the connection between the Router and the Extender?
If so, have you connected e.g. a laptop to the Extender?
So if your WLAN networks SSID is NETGEAR, the WLAN network of the Extender is NETGEAR_EXT and you have to connect the laptop to NETGEAR_EXT.
Then you have to open your favorit internet browser and have to type in www.mywifiext.net, which I guess is a buildin Setup-Assistant.If this doesn't work, make sure, your laptop is configured, to get an ip address automatically via DHCP.
Or read http://kb.netgear.com/app/answers/detail/a_id/20912
Apr 26, 2013 | NETGEAR CONSUMER New - Netgear Wn3000rp...
I purchased a Netgear Universal Wifi Extender for my ipad, i've set it on on the ipad and it says its connected and evreything and the little correction mark comes up on the ipad showing connected. the...
Extender means it extends the existing Wifi or network. So the iPad now connects fine to the extender, but the extender needs to connect to the existing network either via Wifi or cable. You need to open from the iPad the admin page of the extender and find the connection details there to your existing network.
Nov 20, 2017 | NetGear Universal WiFi Range Extender...
When power goes out Wifi will not connect to laptop
You'll need to find a way to power the wireless extender during times that the power is out. Keep in mind, doing so will only allow you to connect to other battery powered devices that connect to your powered network hardware. This includes, but is not limited to the cable or dsl modem and the router that presumably is used to to provide the network connection to your wireless range extender. This could mean that you're only going to connect to LOCAL AREA devices; not the WIDE AREA devices (the internet). Even with the hardware in your area powered by batteries, it is possible that your ISP is unable to provide internet access to you due to network failure, etc.
If you still want to try, you can power your network hardware with UPS hardware that can provide as little as power to allow for orderly shut down during a power failure - to one that can provide power for significantly longer times - depending on the size and number of equipment you want to connect.
I hope this helps.
Jan 20, 2012 | Hawking Hawkin HiGain HWREN1 Wireless300N...
How to setup up for repeater mode
This particular Hawking device must be configured after it is connected to your LAN and powered up.
Before you can do this, you will need the software from Hawking. If your devices Serial Number begins with HEMCHWREN1 use the link below"
http://hawkingtech.com/products/downloadfile/114.html
If you have a Revision 1 device with a Serial Number begins with HEMCREN1R1 use this link:
http://hawkingtech.com/products/downloadfile/117.html
Once you have the software, here are the steps you need to follow:
  1. Connect the A/C power adapter to an
    electrical source, and then connect it to the
    'Power' socket of the Range Extender.
  2. Connect your Range Extender to a LAN
    port on the Router or AP that you would
    like to extend (repeat) the range on.
  3. Connect your PC to any of the LAN ports
    located on the back of your router/AP.
  4. Now run the appropriate program you obtained from the instructions in the beginning of the answer.
When the auto-load page appears, click the Setup Wizard option on the right and follow the Setup directions.
Scan for your Range Extender by clicking the 'Search' button. Once found, click the device to highlight it and click 'Next".
Choose a name for your Range Extender. You will use this name to identify and connect to your extended network. Optionally, you may change your login username and password. Click 'Next'.
At this point, the Setup Wizard should automatically obtain a new IP address for your Range Extender from the Router. Please wait for this IP to generate into the IP address field. Note the new IP address and click 'Next' to continue.
In the Search box, find the Wireless Network that you would like to extend. This Range Extender works best with other wireless-N networks, but also supports wireless-B and G networks as well. Select your preferred network and then click 'Next'.
For Security Settings, you must make sure that the Range Extender's security settings are identical to that of the Router/AP that is having the signal extended. If you do not know these settings please contact your network administrator.
At this point the Setup Summary displays all configured settings of the Range Extender. If the information displayed corresponds to your desired networks settings, you can go ahead and click 'SET' to apply the settings. The HWREN1 will automatically reboot. Please be patient.
More information can be obtained on the hawking site:
http://hawkingtech.com/products/hi-gain_wireless_networking/range_extenders_&_repeaters/hwren1.html
Sep 24, 2011 | Hawking Hawkin HiGain HWREN1 Wireless300N...
Hawking extender hangs
They just issued new firmware: http://www.hawkingtech.com/support/details.php?CatID=32&FamID=105&ProdID=394#Firmware
You might try that...
-Tom-
Dec 26, 2008 | Hawking 802.11g Wireless-G Range Extender
Local Only
The problem might be that you have good connection to the router but having connection trouble between your router and the internet.
Try accessing your router by typing your Gateway into the address field of the web browser of your choice.
Then click on WAN (Wide Area Network) and check your external IP Address. Beside it you will find a button that says "Renew".
The loss of connection might be the result of poor router configuration, bad cable connection or ISP (Internet Service Provider) connectivity trouble.
May 27, 2008 | Hawking HWREG1 Repeater
Open Questions:
Hawking 802.11g Wireless-G Range Extender Logo
4,412 people viewed this question
Top Hawking Computers & Internet Experts
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
