Necchi 6015 Mechanical Sewing Machine Logo
Posted on Dec 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model 3205FA: needle goes almost all the way down
Model 3205FA: needle goes almost all the way down but won't return back up, seems to be jamming. have taken the top cover off and oiled. After removing the bottom plate I found a small spring laying on the bottom plate. can't locate where it belongs? I rwmoved the needle and same malfunction.
ken dourof
Level 3:
  • Master 980 Answers
  • Posted on Jan 01, 2010
ken dourof
Master
Level 3:
Answers
980
Questions
0
Helped
264454
Points
1919
Email me for timing instructions [email protected]
2answers
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Singer Confidence Model 7470 bobbin jammed, needles breaking, now won't sew
Sewing machines will get out of time, often as a result of broken needle. Search for sewing machine timing or take it for service, otherwise it will simply continue to break needles and possibly damage the machine.
Necchi 544 - won't pick up bobbin thread.
Timing is out...probably due to a recent jam...this is an overview.http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
Serviced more than 2 years ago ??
Overdue
I volunteer at a women's prison in their sewing class and we have model 385-16231301. The bobbin thread does not pick up. The bobin case seems to sit in their properly, but when I turn it manually...
check the needle to make sure that it's inserted correctly, the flat side of the needle goes to the back of the machine,, and make sure the needle goes all the way up into the needle cavity .
make sure the bobbin is correctly inserted
clean under the needle plate area & in bobbin area for loose threads or lint
if none of the above work & the needle is still hitting something then it 's a great possibility it's out of time & needs to be serviced, cause the needle should not be hitting anything when it goes down.
1helpful
The needle jams when i start sewing
Could be threaded wrong - check manual for proper threading
Needle could be bent - check and replace if needed
Needle plate could be damaged - see if any burrs are on it if so take to service dealer and have removed
Bobbin could be wound wrong - check manual
Bobbin could be bent - if so replace.
Necchi Heavy Duty Sewing machine model 3205FA, bend needle while hemming denim skirt, replaced the needle, but now the needle is not picking up the bobbin thread, any suggestions for me to try???
Generally when the needle does not pick up the bobbin thread, it means the needle is either too far in or just plain the wrong length. YOu might want to try lowering the needle just a hair and see if that helps.
3helpful
Have a Necchi 3205FA and trying to figure out how to set it up for serging. DVD wasn't much help.
There is a serger attachment available for that model. When you attach it to the machine you must start the fabric from the top of the foot. The foot won't cut the fabric if you feed it under the foot. You will want to use the Wide zigzag, overlock, or hemstitch stitches. Set stitch length knob on #4 for overlock stitch #1-0 for hemstitch or zigzag. Set the stitch width to the maximum. Make sure the hook arm is inserted over the needle screw so that when the needle goes us and down the attachment will work. Start on the edge of your fabric by making a small cut about 1-2 cm deep and about the same distance from the edge as the cutting blade. This will make it much easier to feed the fabric over and then under the foot. Remember to start the fabric on top of the foot and then feed it under the foot before it reaches where the needle would penetrate.
3answers
Needle picks up bobbin thread but then thread gets stuck
I had exactly the same problem on the exact same model 3205FA. I'm not an expert, but have a little experience on solving my wife and daughter's sewing machine mechanical problems. I would suggest the following: A. Page 6 of the owners manual see item # 1...to be precise it is 1 1/2 times around. B. Page 7 at the bottom, Make sure the bobbin tension spring is set so that there is tension. When holding the tread the bobbin shouldn't unroll. If jiggled about 2-3 inches the bobbin should release about 1/3 of that distance. C. Page 8 at the bottom, ill. # 2. There are two flange holders and screws that hold the bobbin case in position located at about 5 and 7 o'clock. Make sure both screws are tight. This is important. D. Make sure the thread is treaded through the upper tension adjustment properly. See page 9 # Illustration C. Terrible illustration. Keep the dial generally in the green range. E. Put in a new needle, the needles that come with the machine are just short of terrible. Wouldn't hurt to buy good top quality needles for the machine.
Top Necchi Sewing Machines Experts
vince
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
