Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
Posted on Dec 30, 2009
I've loaded all my music into ITunes on my MacBook using the largest file size. Now I can't fit everything I want into my Ipod. Can I resize the files in ITunes without having to delete everything and start over again?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Dec 30, 2009
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
1163
Points
7
You can change the import setting. iTunes->Preferences->General. Click on Import Settings. From here you can change the bitrate to something lower. Or if you are using a AAC Loseless, you can change it to AAC 128kbps. After changing the setting to something else, you can now convert your music. From you music list you can select multiple files and select Create (New File Type) version. iTunes-> Advanced-> Create AAC Version.
After you create a new version of these songs, you should be able to fit them onto your device. It all really depends on weather how you have your songs encoded to start with.
3answers
tip
How to add Songs on iPhone without a PC & iTunes
One of the few things that disappoint me about the iPad is that Apple's flagship tablet is still, to some extent, dependent on a nearby computer and an open window of iTunes or WinSCP. Bridge is a Cydia app which makes importing files to your iPhone, iPad, or iPod Touch without a computer an easier affair. While there are many apps and tweaks that can get content on your phone, Bridge has a special feature which makes it worth the $1.99 asking price.
We've already covered a number of methods to download programs to an iPhone, iPad, or iPod Touch without using iTunes. Some of the free methods include OpenSSH (for secure wireless file transfers from a computer), iTransmission 2 (for torrents), and Safari Download Enabler (for downloading links and video files from the web). The problem is that while these apps and tweaks are more than capable of loading music on to your phone, they don't add the files to the Music app. This means you can't make playlists with the songs you've just loaded onto your phone.
That's where Bridge comes in. With Bridge, you can locate the files you've downloaded to your device and properly import them into your library. You can use this to load Songs, Ringtones, and Podcasts for audio files, set album artwork from your photo roll, and also import movies.
Applying album art to an imported song in Bridge
The only downside is the music won't be transferred back to your computer by syncing through iTunes. That's not a limitation of the app, but a limitation in iTunes. It wasn't built to transfer user-loaded music to your computer from an iPod. If you ever need to import music to your computer, you can use SSH to copy the music over. The files should be stored in 'var/mobile/media/music'.
Bridge can be found in the BigBoss repository on Cydia. Share your thoughts in the comments section below.
2answers
How do I download music from my computer files to my ipod nano
For Apple iPods that are still running their original firmware (not jailbroken) the best and safest way to transfer music and other files onto the device is to use iTunes. You can download iTunes and any tutorials on adding music to your iPod through iTunes at Apple's website. Hope this helps!
Apple iTunes Everything you need to be entertained
1helpful
I have a Freecom 160Gb external drive which I've used to back up various files (mostly photos and iTunes) which were loaded on the pc with Windows Vista installed. The pc recently had a failure o
Windows-based PCs b> Plug your iPod into your computer to open iTunes; if it doesn't automatically open, open it manually. A window will pop up on your computer asking you if you want to sync the contents of your iPod with the contents of your iTunes library. Click cancel. In the iTunes source list, choose the iPod, and make sure that you have selected the Summary tab in iTunes' main window. Open up the My Computer icon from either your desktop or the Start menu, and select your iPod from the window. In the My Computer window, open up the Tool menu and click on Folder Options. This will open up another window. Choose the View tab, and find the heading for Hidden Files and Folders. Click on the button that says "Show Hidden Files and Folders," then click the "Apply" button at the bottom of the Window. Close the Folder Options window. Find the iPod's icon on the desktop and double-click it. This will open more folders in the iPod window. Find the folder called iPod_control and double-click it. Now you will have a number of folders to choose from. Locate the music folder, and drag it to the main desktop so that it's copied to your computer. When the Music folder is on the desktop, right-click on it. From the window that appears, choose "Properties." In the Attributes area of the General tab, uncheck the Hidden option, and then click "Apply." A window will appear that will ask you to confirm the attribute changes. Make sure the box next to the Apply Changes to this Folder, Subfolders, and Files option is checked, and then click OK. Drag the folder and its contents into the iTunes library.
b>
Have memory stick with music for i pod and do not know how to use it
  1. open itunes (apple software)
  2. plug in ipod to computer using the transfer cable
  3. in another usb port, plug in memory stick
  4. when everything has loaded, open the files on the memory stick. Should ask you if you want to open/view files. If this dosn't pop up, go to 'my computer', click on the memory card and go through the files like you would any other.
  5. when you see the music in sight, simply highlight and drag onto ipod or itunes
Somebody copy songs to my ipod nano /and the songs appear on the compter when you plug it in but it willnot down load on my ipod nano
Sounds like they did not use a iTunes to copy the songs to the iPod.
iPods/Phones/Pads, etc require iTunes to create a sort of file that tells the iPod where the music file is located at on the mp3 player.
So if they just plugged it in via usb and drag and dropped mp3 files over then there is no file to tell the iPod where they are.
So you'll need to drag those music files off of your iPod back onto a computer and then use iTunes to import the songs into iTunes and sync your iTunes library to your iPod.
2helpful
How do you download songs and sycronise ipod nano 2nd generation to computer 2nd hand ipod no instruction
1. Double-click on the "iTunes" icon to open the program and then transfer all of your music files into iTunes. To add music from CDs, simply load a CD into your computer's drive, wait for iTunes to see the playlist and then click "Import." To add music from another program,
go to the "File" menu and select "Add to Library." You will then be able to click on any music files you would like to transfer.
2. Plug your iPod into a USB port on your computer and wait for iTunes to automatically recognize the device. You will be asked to name and register your iPod, after which you can click "Finish" and begin to load music.
3. Click on "Library," found in the left hand column to reveal all of the music you have transfered to iTunes. To load songs onto your iPod, highlight one or more songs and then drag them to your iPod. Your iPod will be found in the same column where you found the library, under the name you chose earlier. As soon as you drop the files into your iPod, they will quickly copy.
4. Eject your iPod once you have loaded all of the music you'd like by clicking on the arrow next to your iPod's name. When the name disappears, you can remove the USB cable and begin enjoying your portable music.
Download of ipod music to my MacBook library
if you have plugged the Windows formatted ipod into your mac and then formatted it using the mac, there will be no music left on the ipod. if you want to retain the windows format and the music currently on the ipod, you must say "no" to any offer to format the ipod that the mac itunes may prompt you with.
if you haven't formatted it, then you can use third party programs such as yamipod which allows you to copy music from ipod to your desktop which you can then import into itunes. search google for yamipod.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
