I thought I would install a new elongated toilet after remodeling the bathroom. old toilet did not leak but was small and outdated. To my surprise, there is no toilet flange on the floor and the 4'' pvc drain is just below the tiled floor about 3/8 inch or so. I used a oversized wax ring since I had to shim the toilet from rocking. It did not leak until about 3 months later. The toilet floor is concrete and the floor surface is tiled. The two toilet bolts are cemented in the floor. I thought about using two wax rings instead of the one oversized ring. I'm looking for a easy way out.
Go to a hardware outlet(Lowe's, HomeDepot, etc.) and ask for a commode drain extension that can be placed over the existing and bring it up to the level of your floor. I also like the wax rings with the cup molded in. These can be doubled up also but not as reliable as the extension.
Eric
Testimonial: "Thank you very much!!"
What does this extension look like? Our Home Depot does not offer any good help so if I knew what this extension looked like, I could get it myself. Does it fit into the drain?
