I have a GE oven model number JRS04BW. Recently, all of the lights on the electronic display are lit up and the oven does not work. I am trying to find out if this is something I can fix myself. I have turned the breaker off and then back on hoping that would reset the oven, but the display lights continue to stay on and the oven does not work.
SOURCE: "Door Locked" flashing on GE Oven JTP15 - can't unlock
The problem may very well be in one of the micro switches on the self cleaning motor bracket. These switches control the electrical flow to the heating elements. In the owners manual there is/should be a chart that lists the unlock and safety combinations. This would be your best source of information.
SOURCE: F7 appears on GE double oven JT950SA
f7 is a stuck keypad or overlay all you can do is replace it
SOURCE: 326B1230P001 GE Double oven that displays ?F7? and beeps
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Send an e-mail to Charlie at [email protected] for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
SOURCE: GE JTP27 oven, ERC display completely lit, keypad
Yes, this is a problem with the ERC. You can buy a new one, or we can rebuild it for you.
Best Regards,
Bruce
www.fixyourboard.com
SOURCE: self cleaning oven troubleshooting
turn breaker off then back on put back in self clean the cancel it
All parts come with a 365 day, any part, any reason return policy.
