There are two basic ways to restore Acer 5315 PC Notebook to the original setting. The first method you can try to pressing the key Alt + F10 for 5 times while startup process appears on the Acer screen. Usually this way will restore the original setting automatically.
And the next method you may need to use system restore at the first time you’ve got your Acer 5315 laptop. Here are steps to follow:
Log on as the Administrator => Start => All Programs => Accessories => System Tools => and click the System Restore. System restore will run and here you should see the Welcome System Restore page appear. Click Restore my computer button to an early time if it’s not already
selected. Click next to continue the steps.
There is on your Acer 5315 laptop screen a Restore Point page appear, you can select it and then click the most recent system checkpoint it, click a restore point list. After you click the Next button, System Restore message may appear that lists configuration changes that
System Restore will create. Click OK.
For the last step click next button on the Confirm Restore Point Selection page. Now the ‘System Restore’ will restore the previous Windows XP configuration on your Acer 5315 OS system. Just finish it by restarts your Acer laptop.
Now log on again to your Acer 5315 PC Notebook as Administrator and watch the System Restore Restoration Complete page appears. Click OK.
Hi the alt f10 reset does get you started but shoptly after you begin it does ask for some stupid empowering technology password..............anyone know what to do? Thankfully Nick
I am trying to do an original setting restore to my Acer 5315 labtop and the message it gave me after I press Alt + 5 times to startup and this message came up "Please enter the empowering technology password"
it did the same thing for me but I have no clue what the password is...anybody know?
000000(six zeros)
dont try it if you have a bt hub 3 it screws up
SOURCE: restore settings
hi the above is not true ..i have restored many acer laptops ..its very easy to do ...start the computer up you will get the acer logo first then a black screen with a cursor in the top left corner (this only stays on for a few seconds .) when this screen (black screen with cursor) comes up immediatly press alt and f10 this will then bring up a screen that says windows system restore ..just follow the on screen instuctions the first one will be 4 options as to what you like to do ...you need to do complete factory restore (think its the first option) and thats it just follow what it does and asks you to do ..be aware that you will loose everything you put on the laptop ..that wasnt already there when you purchased it ..every computer has a original copy of the factory settings and windows hidden on the hard drive ..your computer will be restored to the brand new condition it was in when you bought it ..dont worry if it seems to take a while and doesnt look like its doin anythin.it is and can take anything from half an hour to an hour for it to do it all...the computer companys and fixers dont like you to know this but trust me ive done loads of acers this way ..and sonys and gateways ..the trick is is to no what buttons to press on start up to access the windows restore facility ..an acer is alt and f10 ...hope that helps.
SOURCE: acer aspire 5315 laptop cd/dvd drive stop working like there was none
This will be one of two things, 1- a driver glitch, you will need to uninstall the drivers for the cd/dvd drive from the device manager, then reboot. The machine will find the drive and reinstall the drivers automatically. This will fix it if it's a driver problem. You can also try any updated driver utilities, or patches for the drive from Acer's support site. 2- the cd/dvd drive has failed and needs replaced. These are basically plug and play devices, they either work or they don't, so a majority of the time when the machine stops recognizing the drive, it's because the drive has malfunctioned. Unfortunately, these drives are considered sealed units and replacement parts aren't available.
SOURCE: Acer Aspire 5315 laptop, Ubuntu, microphone
This is due to the drivers. This will require a kernel build and the drivers to be checked. check the Ubuntu forums for a kernel build for your Acer there should be a script to correct this already written.
SOURCE: Acer Aspire 5315 No Recovery Disk - Restart
yes you can use the recovery partition which should be built into the hard drive. press f2 on the bios screen and follow the on board instructions. this will return the laptop to its original factory state. Keep in mind that this is a destructive reinstall of windows and you will lose all data and programs.
make sure you do a recovery and NOT a system restore to earlier date.
hope this helps.
