Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Builders installed my underfloor heating with the Wickes programmable thermostat, however they threw the instructions for set up away. Where can I get replacement instructions on how to set the timer please? Wickes 24 Hour Programmable Floor Thermostat
Jude Meredith
  • 417 Answers
Ive been looking for about 20 minutes now and unable to find a direct link to the owners guide, I did locate the phone number for wickes support for you..
Please contact our Customer Services on 0870 608 9001 and we will be able to assist you.
jm
Posted on Jan 02, 2010
Testimonial: "Great thanks!"
Gaurav Narula
    New Friend:
    Problem Solver:
  • 5 Answers
Firstly, you have to conduct an experienced HVAC professional for the underfloor heating system problem. Replacement can be done if this product is in guaranty period. For future remeber that pre-season maintenance also plays an integral role in avoiding the system failure during the winter, when you need them the most. Moreover, regular maintenance also helps in keeping your energy bills from blowing out of proportion.
Posted on Apr 08, 2016
My radiant floor heating suddenly stopped working. Wall thermostat is functioning normally. GFCI test is working fine. What can I check next?
Monica, There might be a break in the wire mat, you or a electrician will have to check with a digi multi meter.
Links below show how.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to test underfloor heating with multi meter
How do test the resistance of my electric underfloor heating system
http://www.suntouch.com/support/troubleshooting
Testing underfloor heating
Mar 02, 2016 | Heating & Cooling
Underfloor heating wont stop running
Look for a stuck relay that controls the pump
Dec 30, 2013 | Hunter Mechanical Heat & Cool Thermostat...
I have just installed underfloor heating with 4 zones. I also have the existing radiator system. The radiator system is currently programmed to come on and off twice a day but has no room thermostat. We...
You say you have3 rooms on the underfloor system that will probably require different temps. You said you have 1 zone valve for the under floor system. You can not control all the rooms with different thermostats and only 1 zone valve. You need more information and professional help here. I can give you more advice too...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 22, 2009 | Honeywell Programmable Thermostat Heater
Thermostat does not stop heat pump unit
Most of these problems are the program settings on these way overcomplicated thermostats. You will need to re-read the instructions on setting the programs. Or bite the bullet and buy a cheaper and simpler one. If you installed it yourself, make sure the settings on the inside are correct, like gas/electric heat, and 24 volts, stuff like that.
Jan 22, 2008 | Honeywell Programmable Thermostat Heater
Installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
Dec 04, 2007 | Honeywell Programmable Thermostat Heater
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
830 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
