Question about Intuit QuickBooks Pro 2008: Windows
I am getting error code 6129,0 when I try to open any of my companies. Help
Posted by castlegames on
  • Akshay M
    Akshay M Jun 30, 2020
    You can solve this drawback by corporal punishment many solutions urged by comprehending. Your drawback could also be resolved with one, or it’s going to be necessary to follow all accessible solutions to correct the matter. you ought to do these solutions consistently in order that you get glorious results.
    Solution 1: If you get this error whereas attempting to update the corporate file.
    First, open a brand new file to envision if this error seems on your company file or is it with all different company files. you may use your administrator login details to log in to Windows and update the file. If you can not log in to victimization your own admin login details, you’ll get technical support for Windows.
    Solution 2: after your expertise easy-step interview you’ll try this resolution
    Click on vacation whereas you’re within the easy-step interview.
    If you see the message “Save File”? Click on affirmative.
    Enter a novel name for the file so click on the Save choice.
    Solution 3: Disable antivirus if you utilize safe mode on Windows
    Restart your system while not ever-changing safe mode.
    Disable running any firewall & antivirus
    Note: ne’er use an online association after you disable running antivirus. Before running antivirus code you have got to disconnect your system from web association. As shortly as you complete this method by following the subsequent steps, you’ll re-enable the antivirus code while not reconnecting your system to the net.
    Create another company file.
    Put your system in traditional mode and restart it.
    Open the QuickBooks code so open your company’s files
    Solution 4: Rename QuickBooks Network Descriptor Files
    Find Your system’s disc drive files that host the shared folder of QuickBooks company files
    Right-click the network descriptor file and rename the choice with the name of your QuickBooks company file.
    OLD after you have entered the file name, press Enter and you may see the file name because of the company file name. Qbw.nd.be)
    If you discover a file on multiple systems, you ought to follow consecutive steps. after you are victimization QuickBooks code on a system, you have got Associate in Nursing choice to open the corporate file like a shot.
    Click on the Windows begin button and select Programs> QuickBooks> QuickBooks info Server Manager.
    Click on the scan folder.
    If there is no folder that includes the corporate file, then you have to click on Add Folder and add it.
    Click on the scan.
    Click Close after the scan is finished.
    Now open the QuickBooks company file.
    Solution 5: Produce different folder and drive to QuickBooks company files
    Create another folder.
    Navigate to QuickBooks Company Files in the new folder.
    If you are a victim of QuickBooks on a system, it is straightforward to open a working QuickBooks company file in a new folder. But, if you use an equivalent file on multiple computers, you should perform step four.
    Click the Windows Start button and select Programs> QuickBooks> QuickBooks Info Server Manager.
    If there’s no folder that includes the firm file, then you need to click Add Folder and add it.
    Click on the scan.
    Click shut once the scan is finished.
    Then you have to open QuickBooks company file
    If you have liked this article then you must read Quickbooks file doctor
    Solution 6: Make sure that all laptop systems are functioning on one domain
    You should contact a network administrator or Associate in Nursing IT specialists to attach your system to the domain.
    Learn more about
    QuickBooks Hosting Services
    QuickBooks Enterprise Pricing
    QuickBooks for Mac Desktop
masonolivia
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 17 Answers
{{1800/796/0471}} QuickBooks is one in all the most strong and reliable accounting software system that's capable of managing the whole cash-flow of your business. however unlike the other software system, QuickBooks additionally fails to open your company files. Consequently, error message like: QuickBooks isn't responding will pop. So, what to do when QuickBooks isn't responding? What ought to be your start after you get landed into this error. if you're stuck with such queries then you're on the correct place.
QuickQuickBooks is a dynamic application that meets all the requirements of your company. It has an excellent function that enables you to readily finish your duties related to your work. But many times there are bugs and crashes that ultimately destroy your job and attempts.
QuickBooks Repair Software can repairs and restores damaged database of QuickBooks application.This QuickBooks file Recovery software successfully recovers all types of information from corrupt or damaged QBW primary data file of QuickBooks file.QuickBooks software recovers QBW file after all corruption scenarios, like virus infection, improper system shutdown, application malfunction, and user.
There are many people who face a lot of errors when accessing QuickBooks. Every QuickBooks error occurs with a specific QuickBooks error code that shows a note which describes the actual problem. So, QuickBooks error codes may help a userunderstand the main reason behind the problem that restricts you from using QuickBooks seamlessly. You can search for the solution to a specific QuickBooks error code on the internet. If you are not able to find the solution or not able to solve the issue on your own, make sure to contact the QuickBooks support providers as quickly as possible. More info call us toll-free support number {{[[((*1_800-796*0471))}}.
Posted on Oct 07, 2019
Merry Smith
If you are getting any kind of QuickBooks Error Code Message while installing or updating the software. Contact the QuickBooks error support number USA [(+1)-877-756-9341] to instantly. https://www.quickbookstollfree.com/quickbooks-error-support-number-1328-2/
Posted on Aug 20, 2019
Emily Roman
    Problem Solver:
  • 11 Answers
Contact for QuickBooks Customer Support for any QuickBooks accounting help, suggestions, and QuickBooks error. Visit Here: https://www.zeniusgroup.com/quickbooks-support/
Posted on Jul 24, 2019
David Watson
  • 3 Answers
If you're still confusing with QuickBooks Error Code 6129,0 then you need to only one simple thing. Just pick up your phone and dial QuickBooks Support toll-free number +1-800-518-1838 and you get the immediate solution from Intuit Certified Experts. So don't waste your time and call now.
QuickBooks Support 1 800 518 1838 Phone Number
Posted on Mar 05, 2018
micheladamss
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 13 Answers
QuickBooks File Recovery which repairs and restores damaged database of QuickBooks application. This is excellent recovery software which successfully recovers all types of information from the corrupt or damaged QBW files. Some of QuickBooks Error Messages Fixed & Repaired by QuickBooks Recovery Tool like :-
  • QuickBooks Error 6129
  • QuickBooks Error code 80070057
  • QuickBooks Error 6000
  • QuickBooks Error 6000-80
  • QuickBooks Error 6000-83
Posted on Jun 08, 2017
jon markan
    Habit-Forming:
  • Intuit Expert
  • 256 Answers
Solution 1: If you are getting this error and attempting to update your company file.
Solution 2: If you are in the Easy Step Interview, use this solution
Solution 3: Disable antivirus and other software using Windows Safe Mode
Solution 4: Rename QuickBooks ".nd" files
Solution 5: Create a new folder and move the company files
Solution 6: Make sure all computers are on the domain (if applicable)
For more help visit
QuickBooks Tech Support
Posted on Jul 29, 2014
Anonymous
    New Friend:
  • 34 Answers
Error code (-6000,-83)
1.. Your solution depends on what action you were taking when the error occurred. Please choose the appropriate selection.
You are opening your company file
You are storing your company file on a Windows server
You are storing your company file on a Linux server
You are restoring your company file
2.. Intuit recommends more than one solution for this problem. The first solution may solve your problem, or you may need to try all of them to resolve the issue. For best results, perform the solutions in the order shown.
Solution 1: Change the extension if the restored file extension is .qbm or .qbw.adr instead of .qbw
Solution 2: Check for problems in your file name and file path
3.. You are creating a back up
Create a new File Folder on the root of the C drive.
Create a backup and save it to the newly created File Folder.
for more help visit
Feb 12, 2013 | Intuit QuickBooks Pro 2008: Windows
Error code (-6129, 0) - Help
Look here:
http://support.quickbooks.intuit.com/support/Articles/SLN40672
Aug 24, 2010 | Intuit QuickBooks Pro 2007 Full Version...
I am getting error codes 6129,0 and 6073, 816 on my quickbooks 2008. What can I do to open the company?
This error can occur when:
  • Data is converted or restored over a network.
  • Several computers are acting as host for the QuickBooks data file.
  • QuickBooks is unable to communicate with the server.
  • There is data damage in your company file.
If the error occurred when you were restoring a company file from a backup or updating a company file to a newer version of QuickBooks over a network:
  1. Copy the backup file (.qbb file extension) or the company file you want to update (.qbw file extension) to a local hard drive.
  2. Restore the backup or update the company file.
  3. Copy the restored or updated company file back to its original location.
If the error occurred when you were trying to open and use a company file:
  1. Update QuickBooks to the most current release on all computers that open the company file.
  2. Close QuickBooks on all the computers with access to this company file.
  3. On the computer you select to host the company file, switch to single-user mode, and then back to multi-user mode:
    1. Open QuickBooks and open the company file.
    2. Choose File > Switch to Single-user Mode.
    3. Choose File > Utilities > Stop Hosting Multi-User Access.
    4. Choose File > Switch to Multi-user Mode.
    5. Choose File > Close Company to close the company file.
  4. On all other computers that will use the company file, stop hosting multi-user access :
    1. Press and hold Ctrl while you open the QuickBooks program and continue pressing Ctrl until QuickBooks opens completely. This opens QuickBooks without opening a company file.
    2. Choose File > Utilities >Stop Hosting Multi-User Access. If that option doesn't appear, the computer is not hosting and no further action is necessary.
    3. Repeat steps 4.a and 4.b for each computer other than the host computer.
  5. Configure the QuickBooks server for multi-user access:
    1. Click the Windows Start button and choose All Programs > QuickBooks > QuickBooks Database Server Manager.
    2. Click the Scan Folders tab.
    3. Click the Add Folder button, select the folder that contains your QuickBooks company file, and click OK. Repeat this step if necessary to add additional company file folders.
    4. Click the Scan button to begin scanning. After the scan is finished, the company files in the scanned folders are configured for multi-user access.
  6. Open the company file in QuickBooks. If you receive the same error message, refer to Settings required for firewalls to make sure your firewall is properly configured to allow QuickBooks access to your company file.
  7. Open the company file in QuickBooks. If you receive the same error message, open a different company file or a sample company file located in one of the folders you scanned with the Database Server Manager.
    • If no company file will open, reboot the host computer and try again.
    • If other company files open without error, the company file generating the error message may be damaged. For more information refer to Verifying and rebuilding QuickBooks company data.
Jun 01, 2010 | Intuit QuickBooks Pro 2008: Windows
Error code 80029c4a quickbooks easystart 2010
This should help.. restart and then follow this..
To resolve this error, try restarting the computer that hosts the company file:
  1. Click the Microsoft Windows Start button and select Shut Down. The Shut Down window opens.
  2. Click the drop-down arrow and select Restart, and then click OK.
  3. Open Quickbooks and try to open the company file.
If the error continues, ensure that any firewall and/or antivirus software is configured to allow access to the QuickBooks company file and folder.
Jan 05, 2010 | Computers & Internet
Turbotax 2008
Hello There, I found this in their FAQ Guide. Hope this resolves your problems, I know it is a bit of a read. Good Luck!!
What is happening?
Double-clicking on a backup, portable company file, or a file with an extension other than .qbw, the following error occurs:
An error occurred when QuickBooks tried to create, open, or use the company file. Please try again. If the problem persists, contact Intuit Technical Support and provide them with the following error codes: (-6150,-1006).
Or, if you attempt to double-click the data file without QuickBooks open, the following error occurs:
There was an unexpected error reported while trying to run QuickBooks with company file "path location". Error code 80070057.
Note: More than one error message that includes the error code 80070057 exists. If this is not the exact wording of your error message please refer to one of these other documents:
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, QBW, NT, or TLG file from a Google Search Timeline
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, NT, or TLG file from a Google Search Timeline
Error: 80070057, the parameter is incorrect. There was an unexpected error reported while trying to run QuickBooks with company file [path and name]
Error: 80070057 the parameter is incorrect" and "You do not have sufficient permissions to delete files...
If your Error 80070057 is different than the ones displayed, perform a new Search.
Why is this happening:
QuickBooks cannot read the company file because the QuickBooks file extension was changed or is the wrong type (.qbm, .qbb, .qbx).
This error can also occur during conversion or creation of a backup or portable company file if QuickBooks detects data damage in the company file.
This error may possibly occur if the QuickBooks installation is damaged.
This error can also be caused by attempting to open the portable company file (.qbm) without having QuickBooks open.
How to fix the problem:
Verify that the file extension displays company name.qbw and not a shortcut.
Copy the company file, change the extension to .qbm, .qbb, or .qbx, and follow the appropriate steps to open a portable file, backup, or accountant's review.
If the error occurs during the conversion or creation of a backup or portable company file, run the Verify utility to check the file for data damage. If it finds damage, run the Rebuild utility.
Repair the QuickBooks installation.
Uninstall, and then reinstall QuickBooks.
Sep 25, 2009 | Microsoft Windows XP Home Edition
I have been getting error code -6000; -83. What
Might I suggest going to the Getsatisfaction website. I have provided a link that will direct you there.
http://bit.ly/7ebRo
You can use OpenID, Windows Live/Bing, or create a new username.
Hope they can help you out.
Jun 05, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Intuit QuickBooks Pro 2008: Windows Logo
442 people viewed this question
Top Intuit Computers & Internet Experts
Ekse
Mike
SANTHOSH
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
