Question about Kodak EASYSHARE 5100 All-In-One Printer
I was given a computer with Windows XP. At this
I was given a computer with Windows XP. At this time I do not have internet. when I try to load the driver CD for the printer I get the messsage, "KODAK easyshare 5000 series all-in-one software was unable to finish you task. (Erroe code 20x412x0x) Is there a non-internet solution to this error?
Posted by rl9855 on
Anonymous
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 214 Answers
You need to obtain the clear utility software to elimenate the error,it can only be copied form www.kdoak.com/go/clear so you need to be online to get it. Actually the error generated is regarding to your firewall program so you also need to make sure to shutdown your firewall the try again
Posted on Dec 30, 2009
Cant load warcommander on my computer that has windows xp on it
Make sure that your system meets minimum requirement for playing warcommander. If Yes, then download it. If your loading is slow then it means your internet connection has slow speed. I would suggest to download and install Reginout and use its Internet Optimizer feature.
Thanks
I just updated my computer from XP to Vista and i used to use Teamspeak 3 all the time now windows vista 32 bit won't load it!!! Please help!
You may be able to right click on the installation file and hit Run in compatitibility mode and select WINDOWS XP.
1helpful
Windows xp does not shutdown and my computer page fails to load
Sounds like some sort of virus is messing up your world. Microsoft doesn't support Windows XP anymore, (way to stand behind your product, period, right?), you should upgrade to Windows 7.
My computer isvictim of software counterfeiting
Hello ! Dear If you are using genuine copy of windows xp then please try to install Micrsoft Security Essestial if not then try AVG Free from internet which is freely available on internet.but keep in mind you have Windows XP Service Pack 3 (SP3).I am given you a link over from where you can easily download Micrsoft Securoty Essential.Here you go ...http://www.microsoft.com/download/en/details.aspx?id=5201
1helpful
Haha! I deleted folders inside the Local Disk C:\Program files then after that the computer would always ask to restart it, every time I try starting it. Huhu Help, and these folders are not inside the...
Download the operating system from this link: http://www.microsoft.com/downloads/en/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en
or
if you have it, install it using the procedure below:Boot From the Windows XP CD
  • You must boot from your XP . Please make sure it is the same version of Windows that is currently installed on your computer (ex. XP Home cannot repair XP Professional). Place the CD in your CDROM and start your computer. Newer versions will work as well (ie. Windows XP Pro SP2 CD will work on an older WinXP Pro SP1 installation)
    you will be asked to press any key to boot from CD, so do just that.
    Step 3: System repair steps
  • A blue screen will appear and will begin loading XP setup from the CD.
    simply let the CD load without pressing F6.
    Once completed, you will be confronted with "Windows Setup". You will be asked to setup up Windows, or repair Windows with the recovery console. Choose the FIRST option, NOT recovery console.
Choose F8 to continue.
  • Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation or install a fresh copy of Windows XP.
    If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
That should be it. Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts
  • If this solution helped Never go to drive C: again. Vote for this solution and rate it
4answers
1helpful
Applications Closing Instantly
Yes, it sounds like a computer-virus.
Remove the disk-drive from your desktop computer,
and attach it as a "slave" disk-drive to some other desktop computer, and then run a full virus-scan.
Or, just follow "best practises":
* backup your data & music & E-mail & contacts,
* reinstall Windows from trusted media,
* run Windows Update a bunch of times,
* reinstall anti-virus software,
e.g., http://www.microsoft.com/security_essentials
* reload your files.
1helpful
2answers
How to install operating system
Hello
Ok, here is a how to link on installing a clean copy of Windows XP. Just click on the link below where you will be navigated to the site.
http://www.getpcmemory.com/microsoft/how-to-install-windows-xp-step-by-step-guide-to-clean-installation-of-xp/
Hope this can be of help.
Kind regards
ANDREA
I want to down load pantech um175 on computer. the computer i have is windows xp professional
I get this when i try to sign in on youtube Error 7 (net::ERR_TIMED_OUT): The operation timed out.
2answers
Kodak EASYSHARE 5100 All-In-One Printer Logo
Top Kodak Office Equipment & Supplies Experts
Ekse
Joaquim Martins
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
