Question about Zenith H32G48S TV
Zenith tv picture is larger than screen - Zenith H32G48S TV
Posted by nailsbycissy on
Anonymous
  • 139 Answers
Hello
There are Horizontal and Vertical size controls behind the back cover that need to be adjusted using a hand held tool. This adjustment requires a trained tech. High Voltage from the set is dangerous.
However, there maybe some limited controls that may help through the on screen menu.
To get into the setup menu, you need the original Remote that came with the TV.
Hold the Menu Key down until a box appears in the corner of the screen, then press 9,8,7,6 Enter. this takes you to the service menu. Just scroll through the items to find Horiz Size and Vert Size.
Good luck
Posted on Dec 30, 2009
There is no picture and no sound but the volume
Unplug the cable box for an hour,replug it back in.Should get the cable box to reboot to updated the softwares.Might work than,tv seem to have picture,somethings on the screen,words mean ur tv still works.
Mar 24, 2010 | Zenith R56W36 56" Rear Projection...
Zenith TV has me seeing red.
The red gun in the picture tube itself is shorted on. You will have to replace the picture tube itself to fix the problem. Probably want to just buy a new set. Sorry!
Mar 16, 2010 | Zenith B25A10Z 25" TV
Zenith 32" TV picture is larger than the TV screen size.
Adjust the Aspect ratio. The manual will tell you how.
Feb 02, 2010 | Zenith A32B84R 32" TV
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Jan 12, 2010 | Zenith E44W46LCD 44" Rear Projection...
How can I make the picture size fit the screen? I loose picture around the edges. Seems like it is displaying at a larger size
The issue your having is aspect ratio. Some programs and commercials are broadcasting in a higher resolution so some fill the screen and some have black bars top and bottom. I suggest searching "aspect ratio for video". It would take me all night to type it out. But you need to know how the different resolutions change the size of your image. Also in the TV's menu you should see an aspect ratio option. Try the different settings to see if you can find the best.
Aug 19, 2009 | Zenith A25A23W 25" TV
Zenith 32" TV Chirping Noise No Picture
Components in Power supply are bad most likely a 35v 100ufd capacitor if not then your Flyback transformer is bad
Jun 09, 2009 | Zenith IQB32B42W 32" TV
Zenith A32B43W color problem
Classic symptoms! Most of the last TV's made by the old, original Zenith company (Rauland division) had bad picture tubes even when new. This probably had something to do with their going out of business and being taken over by a much better Korean company (LG Electronics AKA Goldstar). Another lovely thing they did before biting the big one was to only sell a complete chassis as a repair part. If your TV is older and has a small white paper tag inside somewhere on the picture tube (usually near the larger brand and type number label) with the code "EIA 1101" on it, discard it. I have NEVER seen one of these work correctly! If the CRT is made by someone else, there may be slight hope. Even if the TV is not very old, if it was really made by Zenith, and not LG, the possibility of repair is slim simply because of the change of ownership. I was sad to see Zenith die such a horrible death. They used to be fairly good, but somehow never made the transition to color TV. After 1954 they were essentially moribund.
Oct 15, 2007 | RCA F32450 32" TV
Zenith 50 In Rear Projection Hour Glass
My picture is a double image and has a sideways hourglass on the screen. Please help me!
Oct 08, 2007 | Zenith IQB50M90W 50" Rear Projection...
Zenith TV E44W46LCD Picture Problem
The PIP module is bad or the video processor circuit. Most likely a main board replacement will be neccasary. Good Luck
Mar 31, 2007 | Zenith E44W46LCD 44" Rear Projection...
Zenith H32G48S TV Logo
216 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
