Canon Pixma MP450 All-In-One InkJet Printer Logo
Posted on Dec 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Canon Pixma MP450 keeps reading ink absorber full. What does that mean?
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Dec 30, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2555714
Points
31058
Like peeling potatoes or oranges or apples, and throwing the peel into a garbage-bin, eventually the bin will get full, and you'll have to empty the bin, before you can do more peeling.
Similarly, when printing, some INK is "wasted", and ends up in a small bin, with an ABSORBER pad (like a baby diaper) in the bin.
So, your printer's bin has become full, and a qualified printer technician can properly empty the bin.
My Pixma iP1200 is reading ink absorber is full - can I fix this myaself? How do I empty it?
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
The waste ink abosorber is almost full This
Pixma MP520 Printer. Waste ink absorber is nearly full message.Anyone know were to buy a new one.
3helpful
I have Canon Pixma MP450, the error is 5B00? how to Fix it? Now cannot use the printer due to this error. Thank you for your attention
Error 5B00 means that your ink absorber is full. you need to reset the counter protection and replace the ink absorber inside the printer.
Visit the link below for instruction on how to reset the canon mp450 printer EEPROM
http://pcmediks.blogspot.com/2010/09/how-to-reset-canon-mp450-printer.html
2helpful
Canon Pixma MP150
Besides service tool, mptool is the popularness software to reset printers canon pixma series like MP150, MP160, MP170, MP180, MP450 and MP460. Excess of software that is the program measure of small and amenity of usage. Ability of the software that is to reset level black and color cartridge at canon pixma mp series. And there also facility to write and read EEPROM in the printer. Other excess this software is detect automatically installing printers in the computer.
Reset Ink Counter.
Reset ink counter that is resetting ink level (ink metrer) cartridge at printer.
  • Reset Black – reset level black ink cartridge.
  • Reset Color – reset level colour ink cartridge.
Reset waste ink counter
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
  • Reset Main (main).
  • Reset Platen (additional).
go to this website download this software after that install it follow by instruction that i give to you do reset....
http://www.mediafire.com/file/yan3ytvdumt/MPTool.zip
1helpful
MP 450...Waste Ink Absorber Full..Does not print
1.Go to: http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
2. Menu 1, select "Multifunction"
3. Menu 2, select "Inkjet"
4. Menu 3, select "PIXMA MP450"
5. Click the "Go" button.
6. Under "Search Our KnowledgeBase", type: "Waste Ink Absorber Full"
7. Click the "Search" button
8. In the search results, select "1. ');includeTableSubmitItem(12835, 'ERROR LCD: The ink absorber is almost full. Press [OK] to continue but early replacement recommended. '); return false;" class="midredlink">ERROR LCD: The ink absorber is almost full. Press [OK] to continue but early replacement recommended. <See manual>"
9. In the next page, select "1. Ink absorber replacement options - MP450". A page will be displayed describing how to fix this problem.
Ink aborsver full
u will need to take the printer to canon service centre and get the printer serviced this problem comes when sponge in the purge unit exceeds its absorbing capacity
2helpful
2answers
What does ink absorber full mean on Canon Pixma 1700?
my Canon pixma keeps coming up ink absorber full cannot print
1helpful
Ink absorber is full on my MP450 Canon Printer
Here this step by step to resetting waste ink counter printer Canon Pixma MP450
  1. You will turn off printer.
  2. retaining button Resume/Cancel (red triangle in the circle) press button POWER - indicator it will catch fire by green color.
  3. you will let go button Resume/Cancel, continuing to retain POWER.
  4. press button Resume/Cancel of 2 times, retaining POWER, after which you will let go all buttons.
  5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!
  6. you will turn off printer by button POWER.
1helpful
Canon Printer Problems
Open the printer, locate the absorber, wash it, then centrifugate to get it dry, install it again and reset the printer.
The absorber is like a sponge filled with ink when it's used.
old marine
old marine
ZJ Limited
ZJ Limited
