Electrolux aqualux 1200 water leaking from door
Posted by rainbow12329 on
  • Anonymous Mar 20, 2014
    door catch broken
mark warfield
  • 452 Answers
Have door gasket changed .....01179512835
Posted on Dec 30, 2009
Hi I have an Electrolux EW Aqualux 1200 in a rented property no manual for the programs would you be able to email me one if available Many thanks rachel
rachel you will find it here if its model number is ew1200
http://www.manualslib.com/download/46075/Electrolux-Ew-1200-I.html
Jun 21, 2016 | Electrolux Washing Machines
I have an Electrolux EW Aqualux 1200. Two weeks ago a sock was stuck into filter. I removed it, switch off/on machine a few times, ran machine empty. However since then machine is spinning only if it is...
9 years a good life for Washing Machine, I can't see why you have this problen , since you cleared it by taking sock out of filter, but expensive to get repairer to look at it , as 9 years old , get a new one . Better than spending money on a repair,
Mar 14, 2015 | Electrolux Washing Machines
My wash/dry cycle has finished but I can't open the door. Is there a manual release please?
turn the dial and listen for a click to release the door. no their is no manual release
Jan 06, 2015 | Electrolux Washing Machines
I have an Aqualux 1200 washer/dryer. After the wash cycle the fabric conditioner compartment of the tray is full of water and the fabric conditioner appears not to have been flushed into the machine
If the dispensers are in their proper spot it is normal for some water to be left in the fabric softener dispenser. When you add your softener add water to dilute it as some softeners are very thick and don't dissolve well especially in cold water
Nov 18, 2010 | Electrolux EW1200i Front Load Washer /...
Washer/dryernot drying-Electrolux - Aqualux 1200 EW
check the drain filter is clear / pumping efficiency good. possible blockage in side chamber on righthand side. fan motor assy on top of chamber may be faulty. a condensing water valve could be faulty its the dual cold valve that the cold hose connects to without it you just get a steam and hot clothes.
Jul 20, 2010 | Electrolux Washing Machines
Electrolux aqualux 1200 ew
hi you need to change your big timer you can have one for 40$ uses
bey good lock
Oct 16, 2008 | Electrical Supplies
I had a similar problem with a different make recently. After cleaning the filter which didn't seem to have anything in it and rinsing the filters on the in and out pipes I took all the clothes out and ran it empty on two different full programmes and somehow the gremlins disappeared and it works fine now.
Oct 16, 2008 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
