Whirlpool upright - freezer part - temp gage on front- alarm keeps coming on and temp reading (-18) disappears . Is there a prob with thermostat? There is power and light is on inside freezer. Advice appreciated
From what I read, the "L." that you see on the control panel indicated that the controls have been locked. According to the manual if you hold down the "alarm reset" button for 3 seconds the "L." will disappear allowing you to control the temperature again. I don't as of yet know what is causing your overall problem though...
The light should reset itself when the freezer gets to less then 18 degrees. If it is still above 18 degrees it will stay on. Now if it is cooler then 18 degrees then unplug the unit for 1 minute and plug it back in once you are sure that it is below 18 degrees. But do not rule out the thermostat. It could have blown out when the brownout happened. To test it jump the wires together and see if the freezer comes on and goes off
You Said, I have a Whirlpool upright freezer AFG 371/H there is a digital display
and lights and buttons, on/off temp alarm etc running across the top of
the freezer. None of this works but the freezer is still freezing. i
have no idea what the temp is.
I think you should try unplugging it for 5 minutes and then try restarting it and see if it reset.
IF YOUR FREEZER HAS A TEMP ALARM, USUALLY LOCATED IN FRONT,BOTTOM, RIGHT CORNER, THE TEMP IS PROBABLY ABOVE THE SAFE TEMP FOR FREEZERS, (10 DEGREES) AND SO THE ALARM WILL SOUND.
THERE SHOULD BE A SWITCH IN FRONT TO SHUT OFF THE ALARM UNTIL THE TEMP GETS BACK DOWN TO ZERO. THEN YOU CAN TURN THE ALARM BACK ON.
IF YOU PLUG IN THE FREEZER AND TURN IT ON, IT SHOULD BE BACK DOWN TO NORMAL TEMP (IF IT IS EMPTY) IN ABOUT 24 HOURS. IF IT ISN'T, YOU HAVE OTHER PROBLEMS. CHECK TO BE SURE THE COMPRESSOR IS RUNNING.
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting
Need to check the temp to make sure its cold enough.. thats what that alarm is for
