Televison & Video Logo
Question about Philips TP3669C TV
It would sound like it was trying to come on butit
It would sound like it was trying to come on but just not quite get there and I was wondering if there was a "reset"button some where like i need a paperclip to reset my car stereo cd player
Posted by loonrk9 on
Anonymous
    New Friend:
  • 10 Answers
The reset button is used to return the unit to its factory settings.
Step1: Turn on your vehicle, but do not start the engine.
Step2: The reset button is located on the right hand side of the deck. Just to the right is the reset button. It is a circular shaped button the size of a pencil lead thickness and it is not labeled. If you have trouble locating the button, use the flashlight to help illuminate the area.
Step 3: Depress this button. If you have do not have smaller fingers, you may need to use a pencil or pen to depress the reset button.
Regards
BEADHZ
Posted on Dec 30, 2009
2helpful
2answers
The passenger front window works sporadically
it is most likely the motor.....when it does this and say that it starts rolling down or up and quits and you wait a minute or so and try again and it starts working again then it is going to need a motor......i hope this will help but if i can help in any other way let me know and give me all the info that you can....let me and fixya know if i was able to help you and a thumbs up and a comment would be appreciated.......thanks and good luck and have a blessed day......
Sound quit working
after what incident the sound stopped /
My Unit just keeps clicking on and off
check your low voltage wiring sounds like a short or in thermostat turn down temp see if it stays on butit sounds like a loose or broken wire
Engine locked up wondering if there are any defects known for a jeep grand cherokee laredo 2000 4.0l engine. Wondering if debris buildup at #3 cylinder location could cause this to happen? if not what?...
you can check the crysler website for any recall
debris on the outside of the cyl. won't do it but
before you sign the death certificate you can
try turning the engine back + forth with 1/2" or
3/4" drive socket + breaker bar and try to see
or hear where it has bound up also remove the
belt I've seen frozen a/c compreser or ps pump
give the same symtems hope this helps
good luck
2answers
Truck won't start. sounds like it's out of gas
put some HEET or some other gasoline antifreeze in your tank and crank the engine over a few times. If it doesnt start, try starting it again every hour or so.
Dvdr610 blew a fuse yesterday this has been replaced butit says start up and it will do nothing no picture or sound [email protected] .com
Probably the power board is damaged.
You should see and check for the FET ( Field Effect Transistor), measure it using multimeter.
Sometimes this is the cause of the fuse blown........
1helpful
My 2005 Jeep Grand Cherokee with 50k miles has total electrical failure. Drove to lunch, tried to start 20min later, remote entry worked, turned over for split second then... total electrical failure. I...
your vat sensor sounds bad.(this is where the chip in the key is not recognized by the vat sensor, and will(in some cases) cause this problemVAT(vehicle anti-theft) module can be replace or it could be your ecm(computer); butit sounds like the VAT sensor problem. The good old days and these sensors wouldn't exist. insert key;start car. Good Luck.
Top Philips Televison & Video Experts
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
