Make sure the TV is on and: 1) Press and hold the Menu button on your TV SET 2) Press and hold the Menu button on your REMOTE CONTROL (at the same time) 3) Continue holding BOTH buttons down for 5 secconds or until the Service Menu pops up 4) Release the MENU button from your REMOTE CONTROL, then release the MENU button from the TV Set. 5) Press and hold ENTER (or OK) on the TV Set, then: 6) Press and hold MUTE on the REMOTE CONTROL (while still holding down the ENTER button on the TV SET 7) Holding both buttons down should lead to the Lamp Life Hours screen to pop up. Release the MUTE button the REMOTE CONTROL, then release the ENTER (or OK) button on the TV Set. 9) Come back to this blog and post your HOURS on our site 10) Now press SELECT, then SELECT again to confirm the reset of the counter
** If the procedure above does not work swap steps 5 & 6.
** For a few special models (including 44SZ8D), you might have to change step 5 to: 5a) Press Enter on the TV Set to enter the Position Adjustment Screen 5b) Press and hold Enter on the TV Set (the TV should go back to the main Service Menu, continue holding Enter) and now also hold down the MUTE button on your REMOTE CONTROL. After about 5 seconds, your Lamp Life Counter should pop up.
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
1-press the exit button on the projector for 3 second to display the total used lamp time.2-press menu button on the projector during the lamp hour message- an adjustement message will be appear press right or left arrow to reset timer to zero.if success osd change to(lamp hour reset ok!)
