Question about Microsoft Xbox 360 Console
I place a game in my xbox 360 console and it says "open tray"
I place a game in my xbox 360 console and it reads.....then says open tray like there is no game inserted....please help... my kids are having a fit
Posted by milkbone4250 on
Anonymous
    Genius:
  • 1,093 Answers
This is not normally the laser or anything wrong with the drive, the reason it happens is because of the receptors on the back of the DVD drive.
All you need to do is stop the heat build up and you should be good to go, you can use a good Xbox 360 Repair guide or send it in.
Posted on Dec 30, 2009
Pablo Gonzalez
  • 733 Answers
Your laser went out, you need a new laser. if still under warranty, send it to microsoft. If out of warranty, i think microsoft charges about $110-$120. The laser is only about $25-$30. ONLY the laser needs to be replaced, not the entire dvd tray which then requires you to install firmware or else it won't work. if you install a music cd and it plays...then it's definitely your laser.
Xbox 360 wont read games
Hello Shawn Francis,
This problem happens to a very high percentage of consumers of the Microsoft Xbox 360 Console, so there is no need to fret. The "Open Tray" problem is a common problem, thus' there is a way you can fix it. Most solutions require you to open the console, unless the solution is banging on the top of the console, which I don't recommend.
- Reader -- When your Xbox 360 console is opened, open the disk tray and inspect the reader. This may be dirty. Try to clean it off with rubbing alcohol and a q-tip. There is NO need to assemble the xbox back together when doing each step. Plug in all needed cables into the Xbox 360 and try BEFORE you re-assemble it.
- Magnet -- Inspect the top cover of the disk tray and you will see a black circle, and on the other side, (underneath the sticker,) a silver circle. That silver circle is the magnet that keeps a game disc in place as it spins. It may be out of place, and causing the game disc to move everywhere, not letting the reader read it. There are several methods to take the magnet and the black holder off of the disc tray top cover, just try a YouTube search. Once that is off, you can place the magnet and the black cover onto the Xbox 360 disc spinner, and the disc tray problem will most likely be solved.
If you have any other problems, or concerns, feel free to contact me at any time.
Wont play games just says reading, open tray.reading, open tray. reading, open tray.u get picture
Xbox 360's disk drive is starting to fail.Knocking on the top of the Xbox (when its on its side) while loading a game cansometimes get it to work, but at some point you will need to have your Xbox repaired by Microsoft or replace it.
2answers
I put in a disc into my xbox 360 and i just keeps reading th disc and saying open tray, I open tray, put in disc and close tray, it reads the disk and just repeats message open tray?? Please help
You can do it yourself by opening the xbox 360 case and the dvd rom with a proper tools.. tighten with a screw (counter clock) right there!! (see the picture)
Open tray xbox 360
my xbox says open tray when theres a game in it
I place disk in console and it says "open tray".
If your Xbox 360 will not play your games this is because of the sensors on the back of the drive overheating it is not normally the laser.
Luckily you can fix this yourself and get back to your games and to do this you need the proven Xbox 360 Repair guide.
Or you can send it in and they will fix it for you the repair will take about 4 weeks.
1helpful
Xbox 360 reads open tray and doesn't show game
Just keep closing and opening the tray, sooner or later it should read the disk.
2helpful
2answers
Xbox 360 wont recognize game discs
your lazer has packed in my sugestion is to buy a new one. i had the same problem
When a game in placed in the console I get an ''open tray'' message
Just put Halo 3 in the drive, set the 360 to automatically play games on Boot-Up, and reboot it.
Tell me if that works.
2answers
Xbox 360 tray
I had the same problem after a while my xbox caught the red light disease
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Joseph Murphy
Joseph Murphy
Daniel Dollive
Daniel Dollive
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
