Question about Acer AL1716WAB LCD Monitor
Acer lcd tv screen goes fluro green, only on some pixels not entire picture but rest of screen is not a very clear picture.
Posted by b_and_e217 on
Anonymous
    New Friend:
My acer lcd 32" tv just recently went of the blink. It has vertical, horizontal lines and fluro green screen. please need some advice...
Posted on Feb 23, 2010
Vizio VF550XVT1A have green pixels wherever there should be black on screen
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
The acer 5536 wireless lan communication button indicator isn't on and the screen is black.
try external monitor to laptop with screen disconnected ,if it works laptop ok screen has problem ,common problem blown fluro light or power to screen and power to fluro ok fluro has problem,check power to screen fluro nil then screen power supply problem or led check wire loom from case to screen power supply.
Acer monitor has green lines on the scren
Liquid Crystal Display (LCD) screens use less energy and display a clearer picture than the Cathode Ray Tube (CRT) displays that preceded them. These new LCD screens now dominate the computer monitor market. From time to time, however, pixels can become stuck and a green line can display on the screen. Removing this line is sometimes possible without sending the screen to the manufacturer for expensive repair.
Locate the pixels that are stuck on the screen. Download a free screen repair software program, such as UD Pixel or JScreenFix. Run the software and allow it to find and attempt to repair the stuck pixels. Turn off the LCD monitor. Apply the damp cloth directly over the stuck pixels and use a gentle pressure to spread the liquid within the screen.
Things You'll Need Pixel repair software Damp cloth LCD screen 5 Ways To Fix A Stuck Pixel On Your Screen
http://www.makeuseof.com/tag/best-software-solutions-to-fix-a-stuck-pixel-on-your-lcd-monitor/
2answers
I have a discolouration mark on the screen that I believe was cused by holding a dvd on pause for too long. It has been suggested that I degausse the screen. Can this be done?
depends on what type of tv it is , if its a cathode ray tube tv then yes you can, if its a lcd or plasma then no you cant, you could try a program called pixel protector on the latter two types of tv, this will play white noise continuously on your tv to try to make the pixels rest , there is no guarantee that it will work, but worth a shot at least
Sony Bravia 52" 1080p LCD Full Pixel Mode Screen Problem
HI NORMALY WE ADJUST THE PICTURE THROUGH SIZE PLEASE GO TO PICTURE SIZE ADJUSTMENT AND ADJUST THE SIZE
THANKS
MUHAMMAD NASIR
My 20 lg powers up, red light turns green, but no picture comes up, the channel id shows then it goes dark. I can wait up to ten minutes still no picture unless I change the channel a few times then it...
You wont want to hear this.....
Green dots on a LCD screen are burnt out pixels and unfortunately are incurable other than having the TV serviced at a high price. One of the reasons it is a good idea to get a warranty on these types of TVs is primarily due to this very problem....burnt out pixels.
Please rate my help++++Thanks for using FIXYA
1/3 of screen is brighter than rest
You most likely have a faulty CCFL lamp, this lamp is a mimi fluro tube.
For service, parts and DIY info check out LCD Parts WEB site - click on this link : -
www.lcdparts.net
Lcd tv with wrong color on one pixel
LCD screens occasionally have what are called "Stuck pixels". There is a tutorial in wikihow which might help you out here:
http://www.fixya.com/manuals/w153177-fix_stuck_pixel_lcd_monitor
Try that and see if it helps. Stuck pixels are actually a slighty common problem.
1helpful
Monitor colours are only fluro purple & green!
use a 10 ins, speaker magnet to front of picture tube degussing color
Acer AL1716WAB LCD Monitor Logo
Ekse
Steve Sweetleaf
Steve Sweetleaf
