Sony HDTV 3LCD 55 inch says Projection Lamp is nearing end of life replace soon. How long should the lamp last and where do you look for the lamp to replace it?
Have you changed the lamp? If not the lamps life is around every two to three years. The lamp is easy to change out. Most local repair shops carry the lamps. Hope this helps.
Most common resolution to this is to replace the lamp. When nearing the end of life cycle for the lamp, it will either warn you with a "Low Lamp Life" on the display or cycle power on/off. Replace the lamp and the problem should stop. Other possibility AFTER you replace the lamp and have the same issue is the ballast board. Not as common, but it happens. Your lamp has a life cycle of approx. 6000 hours, give or take. Replace with ONLY the Phillips factory bulb. It should be The XL-2200 and can be found on EBAY Google Shopping etc. for anywhere from 120.00 for just the lamp to 190.00 for lamp and housing. It's easy to replace and comes with instructions. Hope this helps
Hi, Question shows it is Sony KDF-55E2000 lcd rear projection that has lamp inside as back light source, when this lamp reaches end of its working hours life, it starts such problem. If lamp has not been replaced in last 2-3 years, then replace it to solve this picture issue, lamp replacement procedure is easy and written in user manual of tv, please buy Sony original lamp from nearest Sony Store for good picture in tv. Thanks.
This kind of problem occurs when lamp becomes weak that means near to end of working life hours but still not dead nor broken. Replacement of lamp in tv will solve your problem, lamp replacement procedure is easy and would be written in user manual. Thanks.
Replace lamp in tv because symptom shows lamp is near to end of its working hours life and causing that problem. If lamp has not been replaced in tv in last 2-3 years, its time to replace it to solve the issue. Lamp replacement procedure is easy and written in user manual. Thanks.
you need to go into the TV's menu and select replace projection lamp menu and follow the on screen instructions to verify and reset the lamp timer, (its in your instruction manual , in detail) , i am awaiting a new phillips bulb for mine, as i always use the original enclosure, no need for extra plastic, and its easy to complete the swap, and reset hours via TV menu
If tv turns off and back on by itself then its problem of lamp that is dying and near to end of its working life span. Replace lamp in tv to fix the issue, lamp replacement procedure would be written in user manual and its easy. Let me know if you have additional question.
Hi, It is clear symptom that lamp is near to end of its wroking life and tv needs lamp replacement. Please replace lamp in tv to get it back in business. Lamp replacement procedure would be written in user manual and its easy. Please buy Sony original lamp for good picture. Let me know if you have additional question. Thanks.
Along with the instructions for the lamp installation, you should have revceived instructions on how to reset the lamp counter. If not, this operation is listed in the owner's manual. If you can not locate that manual, please confirm your model number and I will post the instructions. Since the counter has not been reset, the TV will continue to show the "error" message.
