Televison & Video Logo
Posted on Dec 30, 2009
Need(lost)a fuse for car power cord for a audiovox D1210 want size is it?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Dec 30, 2009
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
1171
Points
6
TV/DVD combination unit
1 Left speaker
1 Right speaker
2 Pair of infrared headphones
Wireless remote control
6 "AAA" batteries
ADS-1225PC AC power adapter with attached 6' cord (12 V/2.5 A)
69" Power cord with cigarette lighter adapter (has installed 5A fuse)
7" RCA cable (has left and right RCA audio jacks and an RCA composite video jack on one end and a minijack connector on the other end)
1 Adjustable shoulder strap (has a maximum length of 47")
4 Adjustable mounting straps (each strap has a maximum length of 3')
One 90-degree coaxial adapter (has a 75-ohm coaxial jack on one end and a slip-on 75-ohm coaxial connector on the other end)
1 Storage bag
1 Mounting bag
Operating Instructions
Product Registration card
Why do i have a white screen on d1210 portable dvd player
That will be the screen driver chip faulty or even the luminance set too high. Try turning the brightness down and if there's a dark picture it's the chip, if not maybe even the flexi strip from the base to screen.
How do you open the unit?
Download the service manual to your set. It will have all details.
I need a power cord. Do I have to have a specific
Usually you can use any power cord just be sure it is the same size as the other one you had.
Audiovox pvd80 region problem
Audiovox code hack For DVD player D1210
1. power on
2. SETUP
3. in setup digit 9653
4. go to new menu VERSION
5. in region use UP/DOWN to change region
6. power off and power on
7. Enjoy!!!
I hope this information helps you with your problem
Screen wont light
Are you still under warranty with this product? Have you tried to reset the DVD Player to the factory settings. You can do this by opening up the menu and on the main page highlight preferences and press enter.Now go to the default setting and highlight it and press enter. This will reset the DVD player to the original settings.If this doe not solve your problem you can call Audiovox customer support at this telephone number. 1-800-645-4994. Give them the model number of you DVD player and tell them the problems you are having. They will be able to tell you how to get the unit serviced. I hope this information helps you with your problem.
1helpful
Audiovox D1210 DVD won't load to play. When we put in a DVD to play a movie, the screen displays "loading" for a while and then reads "no disc". Using a can of air (and sometimes jolting the player itself)...
Your DVD players may have slip out of calibration. You can try setting them back to factory specifications. To do this go to the set up menu main page. Highlight preferences and press enter.Next highlight defaults and press enter. This will reset the DVD player to the factory settings. This procedure is explained in the owners manual on page 26. If this does not solve your problem, you can try using a cleaning disc to clean the laser head and transport. This should restore the laser, and transport so that you can use it. If you are still experiencing problems with the DVD player, you can call Audiovox customer support at this telephone number. 1-800-645-4994. Give them the model number of you DVD player and tell them about the problem you are having with the DVD player. I hope this information helps you with your problem.
Audio yes, picture no!
You can try to reset the DVD player to factory setting. Go to the set up main page. Highlight preferences and press enter. Go to the defaults setting and press enter. This will reset the DVD player to the original factory settings. If this does not solve you problem you can call the Audiovox customer support telephone number. 1-800-645-4994 Give them the model number of your DVD player and tell them the problem you are having with it. They will be able to tell you how you can obtain service for your problem. I hope this information helps you with your problem.
Audiovox d1210
We bought this player almost 5 years ago, and have the same problem. When we called audiovox at the time they told us that it was because some of the dvd mnufacturers had changed the format/technology in which they recorded the dvd programs. The biggest problem was with the Disney dvd's. Also, that they did not have any software upgrades at that time to upgrade the player. We used it for a while with the hit and miss movies that it would play, and then finally shelved it and bought a minivan with a preinstalled dvd player. Very rarely use the audiovox now. I am surprised; however, that after 5 years they would still have the same problem and have still not yet upgraded the software in this player. Good luck.
Top Audiovox Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
