Televison & Video Logo
Posted on Dec 30, 2009
There are sets of lines going across the top of the screen.
I have a CTGV-3249. There are sets of lines going across the top of the screen about two inches down. They seem to be coming down further as time goes on.
Anonymous
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Dec 30, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
28
Questions
0
Helped
3610
Points
85
Probably its finely out of tune, i would get onto settings then manually tune it myself. or if this fails.. call your service provider. its nothing that you have done wrong. its them. also. at the back of your television. make sure ALL essential leads are fully plugged in..
1helpful
Lowrance HDS 10 Insight downscan screen shows a white line across the top of screen. The rest of the screen is blank except for that tiny white line that scrolls at the very top of the screen.
Yes you reprogrammed your unit to bottom depth.
Go to settings and use the arrow buttons until you get to the top of the unit. The menu will have several different settings you need to change the sonar settings. After you play around with all the different settings you will see what I'm talking about.
Walld"
Sep 30, 2019 • Boating
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Why my seiki 32 in has 2 inch line going across top
on the remote look for a button called apex and push it 3 times while looking at the black part od the set.
Terry
I bought a 32' ctgv-3249 series at a aucton and there is no color
Hello
If the picture is correct in black and white mode and sound is Ok, your TVs chroma section is in trouble. At present sets, this section consists of an Ic. That Ic may be not working. There are many reason for which chroma section cannot work. Consult an experienced technican to rectify the trouble. There is an oscillator section inside the chroma Ic which receives its oscillations from an ouside crystal oscillator, usually oscillates at a frequency of 4.43361879Mhs or 8.86Mhz or may differ its frequency according to the circuit designs of that tv. Your technician will detect it and rpace the same if needs. You yourself cannot detect the exact point of fault. It need digital multimeter which can count frequency also.
9helpful
White flickering line across top of screen
Set the screen format using your TV's menu. Do not set the format of the screen using your provider's receiver. I had this prob with a few channels with a dish provider when I set the format with the remote from the dish provider. I picked up the TV's remote, went into the menu, set the format, problem fixed.
1helpful
White line going across screen of i pod classic
U HAVE A SCREEN IPOD CONNECTION PROBLEM, U  HAVE TO GO TO AN APPLE STORE TO FIX IT
Red line across top/blue line across bottom of screen
Adjust your convergence. Under menu I think its the last choice at the bottom of settings or picture menu
3answers
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Top Broksonic Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
