It has worked great for about a year and a half. During this time , it blows warm air and fills up once a day (40 pints).
Now it blows cold air and doesn't fill up with water.
Is the condensor gone and if so, is it worth fixing?
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
It just blows air. I've had it for years and it worked great until just a few days ago.
Worked great for years until just a few days ago.
