Car Audio & Video Logo
Question about Car Audio & Video
Installing a Sony CDX-GT09 in a 2002 VW Jetta- power, no sound
I am installing a Sony CDX-GT09 in a 2002 VW Jetta w/ monsoon system. I get power, but no sound. Is there an amp issue, if so, what color is the amp wire?
Posted by albertsbk on
  • 1 more comment
  • albertsbk Dec 30, 2009
    I hear that the VW has a built in amp, ( I did not add one).
  • Anonymous May 11, 2010
    if you have a separate amp in the car then you need a remote feed to it to start it or to bypass direct to the speakers, the feed from your new head unit is blue but as for the car you need a wiring diagram for the model car & amp set up
Anonymous
  • 43 Answers
Definatley amp issue there should be a green wire with a red stripe in your harness, if you take the blue wire with a white stripe from the sony deck and hook it up you should have sound. good luck
Posted on Jan 01, 2010
1helpful
Beeping Sound on my 03 VW Jetta
EPS is the electric power steering assist. That is different from the EPC light that is the traction control. Could be that the brake shop did not reset the system properly or they messed up a sensor.
VW beetle monsoon radio displaying error code.
Did you get the answer? I am having the exact same problem with my Jetta.
We recently replaced a glowplug on our 2003 VW Jetta tdi. We had to disconnect the power source. Since then, the door alarm wont stop ringing. We can't find the factory reset code. Can you help? Oh, it has...
Removing the battery connection for this procedure will cause diagnostic trouble codes to be stored in the engine control module. Erasing these DTCs and resetting the readiness code will require Volkswagen scan tool VAG1551/1552 or equivalent. The same results will occur when disconnecting engine management components while the key is in the on position. Some driveability problems may be noticed until the system re-adapts to operating conditions. OBD II readiness codes, which may be required for emissions testing, may also be erased. Convenience electronics (alarm systems, interior light control, power locks, mirrors, and windows) may need to be re-set using a VAG 1551/1552 or equivalent sacan tool.
After market stereo installation help
You'll an stereo install kit. I comes with the surround for the new stereo to fit into, and that will fit into the space for the stereo in the dash, this kit will also have a connector to wire the new stereo to, and plug into the stock stereo plugs.
Poor radio reception
Chk. for a poor connection wear entenna plugs into radio, it could have corrosion or it could just be loose.
The monsoon system in my 2002 VW Jetta stopped working completely
Pull fuse 14 and reinsert.
There is also an inline fuse in back of the radio itself.
1helpful
I bought a used 2003 Jetta for my daughter with only 12,000 miles on it. The Monsoon radio suddenly stopped working. The display shows FM 88.1 (the radio staion) but there is no sound and the radio is...
I have come to find out that in the 90's auto makers started installing factory amplifiers in their cars so they could use low wattage stereos in the dash. It's usually a blue wire off the stereo that runs the amp, maybe it couldve become disconnected? I also know that even if you put in an after market stereo, this wire must be hooked up or you'll get no sound from the speakers. hope this helps.
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
