It sounds like your camera is experiencing a mechanical issue with the tape mechanism. Here are a few steps you can take to try and resolve the problem:
Power off the camera: Turn off the camera and remove any power sources, such as the battery or AC adapter. This will ensure the camera is completely powered down.
Eject the tape: Look for a manual eject button or lever on the camera. It's usually located near the tape compartment or on the side of the camera. Press or slide the eject mechanism to try and release the stuck tape. Be gentle and avoid using excessive force.
Gently assist the tape: If the tape doesn't eject smoothly, you can try gently assisting it using a small, non-metallic object like a toothpick or a plastic tool. Carefully insert the object into the tape compartment and try to guide the tape back into the cassette while the eject mechanism is activated. Again, be gentle to avoid damaging the tape or the camera.
Reset the camera: After removing the tape or resolving any potential jam, reinsert the power source (battery or AC adapter) and turn on the camera. This can sometimes reset the internal mechanisms and restore normal functionality.
If the above steps don't resolve the issue, it's advisable to contact the manufacturer's support or a professional camera repair service for further assistance. They have the expertise to diagnose and repair mechanical problems with the camera's tape mechanism. Make sure to provide them with all the relevant details about the issue and the steps you've already taken to troubleshoot it.
It sounds as though it's jammed. If you're mechanically inclined you can unplug the unit, take the cover off, and manually eject it. Just look for the motor that drives the load basket and manually spin the shaft. The guide-posts should retract towards the tape and the basket will then lift and eject. Just be aware that whatever bit of tape that's out of the cassette won't spool back in. You will have to do that bu hand once it's out.
When you're done, plug it back in and let it cycle then put an old cheap tape in and see if it works. If not, take it in for repair.
Sometimes the tape is stuck on the head . Open the door and try to pry off the tape from the head with a thin instrument . Power up the unit and usually it spits out the cass. This worked for me many times.
The elctromagnetic tape may be jammed inside. Open the front access to the VHS and inspect for some jams such as toys (if you have kids). You can try grabbing the VHS tape with something while pressing the eject button. Sometimes it needs some assistance to overcome the jam. Good luck!
your cassette seems to be jammed, try removing the player open it which should reveal the trapped cassette then try to carefully remove the tape as it may have got stuck around the capstans(rubber bits) sometimes when tapes haveen't been played for a long time they tend to become loose, try to ensure that the tape is tight by using a pencil inserted into the spool and turn it until the tape tightens please take care not to over tighten. good luk
There is no manual eject.
The only way is to disassemble the camera outer shell, then remove the drive mechanism and using a 4.5 V power supply power the eject mechanism.
It takes 30 min of work when you know how to do it.
If you find the service manual (free somewhere in internet) it will tell you how to open the camera.
Hope this helps.
