The suction still works but the primary floor vacuum doesn't. I checked the belt and its not broken. The engine that runs the floor vacuum doesn't engage like it used to
Re: The suction still works but the primary floor vacuum...
The belt doesn't have to be broken to affect the the way the vacuum picks up on carpet. If the belt is stretched then it will slip and not turn the roller brush properly. Here is the manual and belts you need:
If you have fixed the suction at the bottom, a new tight belt is important when vacuuming carpeted floors. Belts lose elasticity from being stretched which is why they need replaced frequently.
On the right side of your vacuum head, there is a green belt indicator light. If when the unit is powered on and this light is not lighting up, you have a broken belt, or you didnt properly latch the belt in place.
a) Broken belt- you can use the belt from your shampoo'er if you have one, otherwise your nearest Kirby distributor has them for a couple bucks
b) As for the suction, the Kirby has 2 motors. 1 motor is for the cleaning of the floor, the other motor (where you see the vent on the left side) is for keeping the unit cool to expand the life, which btw average life of a kirby is 20yrs and they all come with a lifetime refurbishing plan. If your not getting any suction check the boot of the bag where it hooks onto the unit for any clogging
Check for a broken beater brush belt.
Clean the beater brush, clear of all debris and add some WD40 at each end where the rubber holders are. Turn beater brush by hand to work the WD40 into the axle.
Reassemble making sure the belt is on correctly.
This should also help solve the suction problem as well.
There are two things that you should check on this vacuum after running it without a bag inside. The first thing you should check is the filter that is underneath of the vacuum bag. This filter is underneath of a bracket, and the bracket can be removed by pulling straight up on the bracket. The bracket and filter are directly below the vacuum bag inside the vacuum bag housing. If the machine was run without a bag (or the bag fell off) then this filter is most likely going to be extremely clogged. You can simly remove the filter, and run it under hot water until clean. Make sure the filter is 100% completely dry before putting it back in the vacuum and using it. Running the vacuum with a wet filter will destroy your motor.
Now in terms of the belts. Where as the belts don't directly control the suction of the vacuum cleaner, they certainly facilitate the pick up of dirt and debris on the floor. Many people assume that since the vacuum is not picking up from the floor, then the vacuum doesn't have suction. You can test this by pulling out the attachment hose and feeling for suction, is there suction at the end of the hose? If yes, then the reason the vacuum is not picking up on the floor is because of the belts. If you don't have suction at the end of the hose, then you have a clog, some where or a dirty filter.
The belts actually are what spin the brush, and the brush basically sweeps the carpet, and throws the dirt and debris into the suction port, and when the dirt and debris are near the suction port, the suction then takes over and takes it to the bag.
There are two belts on this model, it's best to replace both of these belts at the same time. If you replace just one, then the other belt will wear out quicker. It's always best to replace these two belts in conjunction.
Once you have the belts, and you're ready to replace them, here's a great video that we shot here at Govacuum.com that shows you exactly how to replace these belts, as well as some basic maintenance on your roller brush;
I really hope that my repair solution was helpful to you in fixing your vacuum cleaner. If you have any further questions about this repair, or any repair, feel free to contact me at [email protected], or request a clarification here on Fixya.
If you did find this repair solution helpful, please kindly rate this repair helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of this solution.
That means that you need to replace the belt. The belt is what turns the roller brush, and when it is stretched or worn it doesn't. You can get replacement belts here:
drive belt. take housing apart (draw a diagram so you can put it back together) take the broken belt to a vacuum repair shop to get the same one. mine cost 7$.
15 minutes work.
You need to replace the belt that drives the brush on the underneath side of the vacuum. To do this, you need to flip the vacuum over and remove cover plate. There you will find the broken, or stretched out belt. Remove the brush and place the new belt on the chrome axle. Then put the brush on, rapping the new belt around the brush as you put the brush back in place.
You have a clog somewhere in the vacuum. Check the hose and the little trap door on the underneath side of sweeper. Does the brush turn? If not, then the belt that drives the brush is broken. Replace the belt
Sounds like you have two separate problems here. If the brush bar does not rotate, probably the belt is broken. This is easily replaced, but you need to be precise about which model you've got so you get the right belt.
Loss of suction is due either to a blockage or, quite often, to a split in the short length of clear plastic hose that leads back from the brush bar enclosure. Repair is possible but replacement is better.
If you need more help, post here again.
even though the belt isnt broken you should replace it also make sure the height is raised up on the nozzle. try dropping a marble through the hose to double check there is nothing stuck ( the attachment hose and the small hose that runs to the floor )
