Nintendo DS Lite Console Logo
Posted on Dec 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have just replaced both bottom screens a little fiddly but no problem but now ds will not start up, put the charger in and the orange charge light apears for a split second then goes off and console will not boot up could there be a wire either loose or off I have looked but everything seems fine????
Anonymous
Level 2:
Scholar:
  • Expert 133 Answers
  • Posted on Dec 29, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
133
Questions
0
Helped
36082
Points
283
Hello!
If you replaced the lower LCD PLEASE check to see if you put a pad on the bottom of the lower lcd... If the metal is touching the board then your LCD and causing the board to shutoff! and not power on.
That's the main reason your DS wont power on if you changed those things.
Also!
Your F1 or F2 fuse could have died out as well.
2helpful
2answers
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Orange light for a second then nothing
Possibly a bad charger? Try getting a new one.
Ds lite suddenly stopped working
The orange light goes off when the battery has been charged to its highest capacity. After every charge, the batteries capacity is decreased. Get a new battery, that should do it.
2answers
Nintendo ds wont charge
cheekiemunke,
First of all, your DS Lite is charging both ways.....with power on and without power on.
You have for almost 99% sure a blown fuse F2 on the systemboard.
If you can solder you can try to replace it with a new one but be adviced, it is tricky if you don't have the skills with soldering SMD components and it can send your DS lite to the trash.
So my advice is find someone that repair DS Lites or order a fuse on eBay and try it yourself.
Regards
John
Charge problem
Sounds like it needs to be repaired. Could be a faulty power supply in the DS.
11helpful
5answers
Nintendo ds orange charge light flicker on then off . no power when try to switch on
i also had same problem and gameathlon solved it wow you can buy it here http://www.gameathlon.com/advanced_search_result.php?keywords=Nintendo+ds+battery&x=0&y=0
2answers
Replaced Bottom screen bypassed fuses still problems
the backlight or fuses are dead. Do not bypass fuses or you'll kill your system.
Ds lite ac wall charger
When you first get the DS it will have a bit if charge on it but only a few hours worth. When the DS charges it usally comes up with a orange/red ish light then that goes out about a few hours later when its charged. ad if you want to chek if it is charging correcly turn the DS on whilst it is charging and the little battery simble in the top right corner should show the battery carging.
25helpful
16answers
Ds light not coming on and charger not working
When I hooked up my DS with the charger the orange light would flicker for only a few seconds then turn off.
I found out that if you KEEP THE DS ON WHILE HOOKED UP the DS will charge. Although, because you are playing/DS is on the charging will go extremely slowly.
Best option, and what I did, was was just return/exchange it. I just did that today.
Nintendo ds
There are a couple of fuses inside the ds and one of them is right up next to where the charger plugs in try to replace it. It is a little flat black piece with solder on each end and it should have a number on it you with need to replace it with the same number fuse.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
