NO YOU DONT NEED TONER YET :()
the printer tells you it needs toner you dont .. take a piece of tape put it on the toner - i printer 200 more pages
see this video this will save you alot of MONEY
http://www.youtube.com/watch?v=hPCGZZIdXyM
Testimonial: "excellent show and tell (demo) of his solution"
You only need to replace the toner, you remove the toner from the drum assembly by pushing the lever on the side and lifting it out, you install the new toner where you took out the old after removing packing material. After installing, you press the go button 3 times and the printout will tell you how much life is left in the drum.
Testimonial: "To the point, accurate, and well described!!!"
SOURCE: toner light still on after replacing with a new one
Drum counter usually has to be reset.. Check user manual or go to Brother's site if you want to drive yourself crazy Ed
SOURCE: HL 2070n
Copier tech here. :P I just had to look this up. looked to the internet first, before going to find a manual.
open front door (the door for toner and drum units)
hold Go untill all four lights are on.
Release Go
Shut door
good to go.
Have a good night ya all.
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
SOURCE: showing drum error and replace toner low message all the time
Open the cartridge cover
push "option"
and push "00"
wait until the word "accept" then close the cover,
after that should be working perfectly.
