Disc does not appear to load. When inserted in player one can hear the machine clearly running but ultimately fails to play and reports "no disc"on screen. Many thanks.
Hello
Your DVD players loading mechanism has some fault with it. It does not load the disc properly in, Check the loading belat first, and the loading motor for low pulling power. Check whether there is any fault loading gear wheels. The fault is clearly of the loading mechanism itself. OK.
You can't add a title to a disc from a player (such as this). You can only add a title on a disc writer before finishing the disc. (The only exception is RW (rewritable) disc which can be unfinished.) If a title (disc, chapter or track) is on the disc you can display it. Press Title on the remote. If you want to read all of the information on any disc, insert the disc and press Load on the player (when in Stop mode) or press the TV/DiscExplorer/DVD button to set the unit in Disc Explorer mode. It takes about 30 seconds to load the data. Press Stop to cancel the data search. Then use the folder buttons (ALL,DVD,CD,A,B,C,D) on the remote or the player to read the various items. Press Return to leave the folders. If you enter the Disc Explorer while playing a disc, the playback will stop and you will have to press Play to restart (Resume is not an available option).
Once loaded the player will store the data even after you remove the disc. It will clear when a new disc is inserted or you press Load.
If you are technically inclined, you may be able to fix this. Any discs not in the carousel correctly must be CAREFULLY removed - NO FORCE. Inspect the carousel for damage. Look at the disc pick fingers and see if they are broken. Remove all discs and run the unit to see if it goes 'home', disc one. With the discs in, you take the chance it cannot run right and damages more discs. I use the clear cover disc from DVD stacks as fake discs. I can see everything the machine does through the clear plastic.
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
I have the same problem with my portable dvd player and found that cleaning the lens of the player using a non-alcolhol wet nap for cleaning eye glasses worked well. I also found the rail that the optics runs along while playing needed a very small amount of silicone greese applied using a Q-tip. You may find that the optic unit may be "stuck" somewhat but can be resolved by gently moving the optic along its guide using a finger.
This changed my unit from not working at all, to working intermittantly sometimes having to vary the player on and off to recongnise the disc. Hope this works
If the disc loads up and you can hear it spin, then you get the error, more than likely the optical lens has been damaged. This will have to be repaired by a local shop if its worth the cost. if the part is available it would probably run anywhere from 130-165 to repair
Try inserting a cd, almost all dvd players can play cds as well, if it displays the same message you may very well have a defective dvd player, if it plays then you may have a damaged disc. If it plays the cd try a mint condition dvd; also, I'll assume that you know better but in many cases if the dvd player is not defective users are simply loading dvds in upside down. If all this fails return your dvd player to the store or check the warrenty.
sounds to me like your laser is gone.
Some discs are harder to play than others as some are multilayed, check online as to whether it is suitable to use laser cleaners these are like discs with soft brushes attached, you can get them from pretty much any computing place, i wouldnt know whether its sensible to use on a DVD player, but couldnt hurt anymore eh?
