Question about JVC AV-48WP30 48" Rear Projection Television
We have an I-Art 48" JVC Model # AV-48WP30. When you turn it on only the top half shows. It's completely bowed in the middle and nothing on the bottom. You can usually turn it off/on a few times and the TV is fine. Now can't seem to get it to get a normal pic no matter how many times turned off/on.
Posted by stormieuli on
Anonymous
This is very common.. you need to go here Re: Convergence problems on AV-48WP30 then read what it says. There are 2 chips to be replaced to fix it.
Posted on Jan 15, 2010
Cheap Fix?
I will strongly advise you to replace the two STK392-120 as a pair. and this will cure your bowing picture problem. You may need to re-converge your set. best of luck.
Nov 05, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 tv(convergence)
This is a convergence board problem. Have a tech replace convergence IC's. The part no. starts with STK. If you are good in soldering and know how to test resistors, you can do it.
Jul 16, 2008 | JVC AV-48WP30 48" Rear Projection...
Av-48wp30
If the convergence Ics and resistors are good its most likely related to the velocity boards that are attached to the Red CRT convergence yoke. Its the small board about half way up the neck of the CRT. If you need one let me know as I have a source for JVC boards for that model.
Jun 28, 2008 | JVC AV-48WP30 48" Rear Projection...
Blue and yellow bowing
sounds like the Convergence ICs STK392-110 need to be replaced you need both of them. You can get new ones at this link and they provide free instalation instructions with pics so you can do the repairs yourself.
http://servicemanuals.vstore.ca/
Apr 30, 2008 | Televison & Video
What's the difference between AV-48WP30 and AV-WP74
They are both the same size screen. (48" diagonally)
width: 106.3cm
height: 59.8cm
C-Dog
Feb 01, 2008 | JVC AV-48WP30 48" Rear Projection...
Bowing red lines at top and bottom of screen
Try this, it might be just the thing:http://www.techlore.com/article/15929/Fixing-My-Own-TV/?textpage=3
Sep 19, 2007 | JVC AV-48WP30 48" Rear Projection...
Jvc Av-48wp30
try unplugging for a few seconds the plug it back in
Jul 11, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP74 48 in.
The convergence circuit needs repaired. I did the same job yesterday on this model. I not only replaced the convergence ICs, but, I had to replace a couple of resistors and a coil. The convergence alignment was minor after that.
Jan 22, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
Top JVC Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
