My ge jvm1650 starts to work for a couple of seconds then blows the 20A buss fuse above the control panel! I'll replace the fuse and the lights and fan will work but as soon as I turn the microwave on, on any setting, the 20A fuse will blow...
It seems like the control panel is malfunctioning. The censorfor external vent fan may not work due to faulty control panel.
You need toreplace the control panel, so that microwave will work properly. Replacing anERC is not a difficult repair and can be accomplished by the average do-it-yourselfoffer.
Hope this will help you. Good Luck.
You have a power fuse inside of the panel that supplies AC power to the panel as well as the klystron tube. This is generally a slow blow 15 amp Buss fuse. Since these fuses deteriorate over time and they are sized to just hold the requested amps (15) to prevent a possible fire. You will have to take the Panel apart and find the fuse, but be sure you flip the breakers as the panel has a High Voltage power section with large capacitors that can produce a nasty shock. Before touching any thing with the breaker power off, short the capacitors to ground to discharge them, then pull and replace the Buss fuse.
Try your oven on another circuit in your house. It is curious that your oven doesn't blow its own fuse before the house one. If it doesn't blow the fuse in the "new" circuit, check to see what is really on the kitchen circuit. It might, in fact, be overloaded. Good luck.
the switch is ok. if it was bad itt would blow the fuse. ge had magnetron problems on the 1600 series. if you have an amprobe and are getting 110 volts from the control to the transformer. place the probe around just 1 wire to the transformer. if you get less than 12 amps replace the mag
There will be a fuse, a cavity TCO (thermal cutout/thermostat) and a magnetron TCO.
These are the parts to check.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
You can find
helpful exploded view diagrams and order parts by entering your full
model number here. (Don't forget the suffix).
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
You can download GE
owner's manuals and installation instructions here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
Check fuse. Remove 3 screws from the plastic grill located at along the top front of the unit. Remove the phillips head screw above the control panel. Slide up and pull out to partially remove control panel. You will see a white fuse. Replacement is CD3G 125v 20amp or BUSS ABC 20 or Little Fuse 314020 at 250v 20a. Radio shack caries the ABC.
sounds to me like the magnatron has shorted out. i don't know of a way to test them unless you have some high dollar equipment. a continuity test prob wont tell you anything. what reading did you get on the cap when you tested it?
