Question about Danco Faucet Cartridge
I bought a replacement Danko faucet cartridge for an american standard bathroom sink and the package said hot/cold but when I installed it on the cold side the handle turns the wrong way. How do I reverse the operation of the handle.
Posted by taffers1 on
James Hall
    New Friend:
Remove the c clip (may be plastic or metal) on the top of the replacement part, the stop ring flips over to make it a hot or cold faucet
Posted on May 13, 2013
Anonymous
    Scholar:
  • 102 Answers
Thae stem you got that said hot/cold were designed to fit old style cross handle faucets. So both hot and cold turned the same way. If the cold side you are replacing turns the opposite direction then you will need to get a cold stem. Danco does make them. Ask the retailer where you purchased the H/C stem. I hope this helps..
Posted on May 27, 2010
Hot water will not work in kitchen
leave the cabinet doors open at night . place an electric heater in front of them an leave water turned on a little
Jan 06, 2014 | American Standard Plumbing
How to disassemble faucet
Make sure that you turn off the hot and cold valves of your water bibs. Take a wrench and undo the nut fasteners on both sides as well as loosen and remove lines unscrew clamp in center and remove pull straight up. Replace with any faucet you desire with the same fit dimensions. John
Apr 20, 2012 | American Standard 3841.000.297 Iris...
IF HAVE A AMERICAN STANDARD KITCHEN (6310) . I JUST READ THE PART TAKE FACTCET APART AND TURN ON WATER . I DID THIS AND GET WATER ON COLD SIADE BUT NOT ON HOT. THIS IS WITH CARTRIDGE OUT .DOES THIS TELL...
It says you have a problem with the hot water. First thing to do is to turn the hot water supply valve under the sink off, and then remove the line from the valve to the faucet at the valve. Then put a bucket underneath the valve and turn it on (carefully). If you don't get any flow, then the problem is in the valve or the pipes supplying the faucet. If you get flow there, then the problem is in the supply line or possibly at the faucet.
Jan 18, 2011 | American Standard Kitchen Faucet 6310 020...
I have an American Standard single handle faucet in the bathroom.. When you open the faucet fully the flow rate is very small. The faucet was fine before. How do I adjust the faucet to so that the flow...
What is likely happening is a small piece of sediment has become lodged in either the mixing valve or in the aerator.
Begin with the easiest part first. The aerator is the threaded attachment from which the water comes out of the faucet. Remove the aerator from the faucet and run the tap without it installed. If the flow rate is good either clean or replace the aerator.
If this was not the problem then the solution becomes much trickier because the obstruction is likely in one of the lines coming into the faucet or in the body of the faucet called the mixing valve. This is where the hot and cold water mix inside the faucet.
Our next step is to create negative pressure inside the faucet in an attempt to remove the buildup restricting the flow.
If you don't have shut off valves under the sink you will need to shut off the water supply to the home, remove the faucet from the vanity/sink and perform the following procedure.
Shut the hot and cold water off underneath the sink and remove the supply lines at the shut off valves but leave them connected to the faucet. You will need to purchase two adapters for the aerator that will allow you to connect a garden hose from your closest water supply (kitchen sink) to the vanity faucet. You can find these at your local hardware store. You will also need a pail under the vanity to catch the water coming out of the vanity faucet supply lines. Connect the garden hose from an active water supply to the vanity faucet. With someones help have them turn the water supply on which will then run backwards through the vanity faucet and into the pail underneath the vanity. Be sure to open the vanity faucet taps to full so that water will run through the faucet. This should dislodge the obstruction.
Jul 24, 2010 | American Standard Ceramix Monoblock...
American standard kitchen faucet roars when hot water turned on
Not the aerator at all as this part would act the same if hot or cold.
Have you checked the shut-off valves under the sink? Sometimes just turning them a bit in either direction will solve that problem (will only be the case if it have been shut off at the valve recently).
Also, maybe the supply line on the hot side have been kinked?
Hope this helps
Apr 11, 2009 | American Standard Plumbing
Danco Faucet Cartridge  Logo
1,271 people viewed this question
Top Danco Home Experts
Bill Johnson
mehan
Level 1 Expert
Tom Chichester
Are you a Danco Home Expert? Answer questions, earn points and help others
