Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED AF-S DX Zoom Lens for  DX SLR Cameras Logo
Question about Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED AF-S DX Zoom Lens for DX SLR Cameras
Not focusing in AF mode camera D300 and D3000
Posted by kristine_gje on
  • kakima May 11, 2010
    Do you have autofocus turned on on BOTH the camera body and the lens?
Anonymous
    Sergeant:
  • 291 Answers
Your motor may have gone bad. Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Posted on Apr 06, 2010
Hello Sir ! Can i use Sigma 70-210mm on nikon D5000 in AF mode?
The Sigma 70-210 f 1:4,5 is an old model, most likely only to be used in manuals focus mode on your Nikon D5x00 camera.
It also needs to be a Nikon version.
Only the Nikon camera's with the LCD screens on top to the right, like D80, D90, D7x00, D300 and above have a focus motor build in, so old AF lenses can be used in AF modes.
My nikon d3000 wont turn on
You cant fix your camera youself call nikon they will advise
if your camera is new they will fix it for free and send it back to you.
Goodluck
2helpful
Does anyone knows how a Vivitar 75-260mm lens will works on nikon d3000?
Vivitar makes lenses with a variety of mounts. Assuming the lens in question has a Nikon mount then it will fit perfectly well on a D3000. If the lens has a Canon mount, for example, then it will not fit at all.The lens is a manual focus lens, so autofocus will not work. You'll have to focus by yourself.The lens also lacks the electronics to communicate with the camera. You will have to shoot in the Manual exposure mode, setting the shutter speed and aperture yourself, without any help from the camera's light meter.
I have problem with the AE-L AF-L button in my nikon d3000. The auto focus is not working fine, i need to press the AE-L AF-L button while taking a picture along with holding the shoot button.Or i need to...
possible error, ensure the lens in fitted securly.
check the all the electrical contact on the lens and body of the camera are clean
if they are dirty this may effect performance.
use nikon recommended products and practice on cleaning your camera.
i hope this was helpful.
The autofocus in my d3000 has suddenly stopped working.maybe i changed something in menu.small ? on bottom left of display flashing.
have you set the selector mode at the lens to A/M?
or else, the focus lock is set as AF-C, for general use just select AF-S mode
4helpful
I have a Nikon d3000 and a Tamron AF 55-200mm lens. I cant get the lens to autofocus with my nikon
The Nikon D3000 does not have a focusing motor built-in, relying on the lens to have a motor. The Tamron AF 55-200mm does not have the necessary motor; it only auto-focuses with Nikon cameras that have the motor in the camera body.
For Nikon lenses, you need lenses designated AF-S. For Tamron, you need lenses designated USD and/or BIM.
That probably wasn't the answer you wanted to see, but there it is.
1helpful
Nikon d3000 autofocus issue
you should change the focus lock to AF-S, instead of AF-C
20helpful
2answers
Nikon D300 - Auto focus point won't move. Autofocus doesn't work.
The lock that's around the 4-way button that moves the AF point will stop it from moving. The AF switch (says C,S,M) on the body below the lens release button gets knocked to manual and turns off the AF
2answers
Auto focus on my d300 does not work
There is a [MF - AF] switch on the camera body where the lens attaches to it.
Move the switch to the AF selection.
AF = AutoFocus
MF=ManualFocus
1helpful
Nikon D300 When I depress the shutter half way or fully on my D300 the frame counter reads r27 and the lens (any previously compatible Nikkor lens) will not auto focus. The camera is not set in burst mode...
Only reason the lens will not auto focus when you depress the shutter half way is due to either lens AF switch is set to Manual OR camera body's focus system is on M. There is 3 way toggle switch below the synch port around the lens mount. It should be set to C or S in order for auto focus to work. If all the settings are correct and even "AF-ON", next to rear dial doesn't activate auto focus then the issue maybe in the setting or the body itself. As for the buffer reading r27, I think mine displays r## regardless of burst/continuous mode.
Top Nikon Cameras Experts
Steve
David Shaub
Are you a Nikon Camera Expert? Answer questions, earn points and help others
