Palm Zire 21 Handheld Logo
Question about Palm Zire 21 Handheld
When using the expenses unable to get a response. Zire21
When using "expenses" unable to get a response when I tap "new" other functions ie. memo & addresses seem OK this is a Zire 21
Anonymous
    New Friend:
I did a hard re-set and I am hopeful that this has fixed the problem
Thank you for your interest
Jan Lamb
Posted on Dec 30, 2009
Need help to present stations on my zenith z1233ba
1) tune the desired station frequency
2) while the frequency is being displayed, quickly press the memo set/clock adjust button.
3) press the desired preset button
4) press the memo set/clock adj button again
5) the station will be stored
1helpful
11answers
What is the easy way to transfer iPhone voice memos to computer?
You have two option:
1. Back up your iPhone to your computer with iTunes.
How to Backup iPhone to iTunes on Windows and Mac
2. Use iPhone Transfer to selective transfer your voice memo to the computer.
DataKit iPhone Transfer copy data among iPhone iPad Computer
Our 9500 series Philips digital pocket memo will not clear the old files when complete. As a result, we are unable to download new files. Any help would be appreciated. Thanks! Jill
Hello You need to Use Philips SpeechExec software for automatic
download, conversion and routing of files
recorded with a Pocket Memo dictation
recorder. How and which files are downloaded after a
recorder is connected can be configured in
the settings menu of SpeechExec or with the Configuration Wizard
Configure the download process
from the Pocket Memo
Pocket Memo is connected can be configured in
the settings menu or the Configuration Wizard.
1 Connect the Digital Pocket Memo to the PC
using the USB cable.
2 Click Settings > General Settings on the
menu bar, select DPM/DT Configuration >
DPM Settings from the list on the left side.
3 Click the Start... button. The DPM configuration
dialog is displayed in a new window.
4 Select Download in the left pane.
5 Select which files will be downloaded
(download file type):
• All files
• EOL (recordings marked as finished/endof-
letter)
• File selection (SpeechExec prompts the
selection of specific files to be downloaded)
• File with keyword 1 (specify a keyword)
6 The download settings also allow the user
to specify if files will be deleted on the
Pocket Memo after they are downloaded.
7 Click OK to save the settings and confirm
the transfer of the new settings to the
Pocket Memo.
2answers
How do I transfer Memo files from my Samsung Galaxy S to PC Computer
Of course, you can transfer memo files from Samsung Galaxy S to computer. First connect Samsung Galaxy S to computer via usb cable. Here, you can use a Samsung data manager tool. With its help, you can easily transfer files to computer.
How to Manage Samsung Galaxy S3 4 5 on PC Mac
1helpful
Can I retrieve my deleted texts from my palm centro and how?
Hello michael_s35,
This is a rather awkward procedure but it will allow you to keep a copy of your text messages on the Centro. Ready? Here it is:
A). In Text Messages
•Open the text you want copied
•Select all of the characters in the message by slowly dragging the stylus from the upper left hand character to the bottom of the text message.
•While the text is highlighted, press the menu button (at the bottom right-hand corner)
•Select Edit in the Menu.
•Select Copy in the Menu. (text is now copied to the clipboard)
B). In Memos
•Press the home key
•Go to the Main category (Main showing in the top drop-down list)
•Tap on Memos
•Tap the New button at the bottom of screen
•Press the menu button (at the bottom right-hand corner)
•Select Paste in the Menu. (text is now saved in the memo file)
•Repeat the above procedure (A & B) for each text message you want to save.
*Each text can be appended in the same memo or saved in a different memo*
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
HTC P3452 TOUCHPAD NOT WORKING
just reset ur mobile. Do not install unnecessry programs. There might be some program causing this.
4helpful
2answers
I've had the acer one for 2 weeks. While using it today, the single and double click functions of the touchpad stopped working. The touchpad still moves the arrow around the screen and the left and right...
Hello cskpuels,
It sounds like the touchpad is working ok but probably needs some setting(s) adjusted. The touchpad settings can be accessed through the windows control panel. But before going to the control panel it's useful to review the touchpad basics for single and double clicking. They are as follows:
•Tap once on the main touchpad for single click.
•Tap twice for double click.
•The lighter the touch, the better the response.
•Tapping harder will not increase the touchpad's responsiveness.
•Opening the Control Panel
The Windows Control Panel can be opened by:
Selecting *Start > Control Panel (on Windows Vista)
- OR -
Start > Run > Type 'Control' and select OK (on Windows XP)
*The Enter key may be used on the keyboard in place of touchpad clicking*
In the Control Panel, do the following:
•Select Mouse [Enter] (Brings up the touchpad properties sheet)
•Look at the Buttons tab in the touchpad properties sheet.
•Adjust the settings and test the touchpad until you get the response you desire.
Have a great day,
martyshaw152
7helpful
4answers
Unable to reply, forward or compose new emails on my yahoo account, will not load emails properly. unable to access any tool functions along top yahoo page (ie check mail, new, what's new,mail classic
Hello laurenloscia
alot of the times, just going into internet options and setting everything to default, and clearing the cookies and files works about 50% of the time.
This is possibly a yahoo issue. If you use yahoo thru ATT, you can call ATT for support and they will escalate any valid issues to yahoo for you.
Their phone number is 1-877-722-3755
ask for tech support at the prompt
they can remote on your computer to see if it is a java issue or whatever
if they can replicate it on their computer also, they will create a yahoo trouble ticket and give you thier member service number. Yahoo resolves 85% of these within 48 hrs.
If they cant replicate it, then they will consider it a pc issue and refer you to connect tech or to best buy's geek squad.
Personally, I would also try sending emails in safemode, If you can do it in safemode, and not in reg mode, it is definately PC related.
To get to safemode, turn your computer off and when you turn it back on, tap the F8 button until you get an advanced screen. Pick safemode with networking with the arrow keys. Log in, click yes when it tells you you're running in safemode, and then when your on your desktop, which will look alot differnt, black background with big icons, click on internet explorer and go to mail.yahoo.com and see if it works now, if it does, like i said, its pc related. If it still cant, call ATT's support if you have thier DSL or U-Verse
spin
spin
Apr 13, 2009 • Yahoo Mail
Need help
Address Book
Contact List
There are two ways to enter Contact List.
1. Tap the [ ] in the idle screen then tap Address Book - Contact List.
2. Tap the [ ] key in the idle screen.
This menu allows you to save and manage contact address information. The
Contacts’ functions allow you to add a new address or search saved contact
addresses by name.
New Contact
This menu allows you to add a new contact address. You can enter contact
address information including name, phone numbers, email addresses, group
information items, memos, ring tones, and image (photograph).
Favorites
This menu allows you to have your own favorite contact list. You can add and
delete it.
Caller Groups
This menu allows you to manage group information. By default, there are 4
groups: family, friends, colleagues and school. You can also configure a ring
tone for a group so that the group ring tone sounds when a call from a specific
contact address within that group arrives and there is no ring tone configured
for the specific contact address.
Can't synch my contacts, calendar, tasks or notes to my Palm m505
In order to remove the username from your Palm m505 you need to go into memo pad, create a new document, now the ticky part, you need to right in grafitti a cursive L (hand written low case l) followed by tapping on the screen twice (will produce one period), then the number 5. To test this you can follow the same procedure but change the number 5 to number 4. You should end up with Handheld does not have a usernameand all of your data will still be retained in your Palm. Now when you go to synhronize on your computer select the new user on your computer.
Top Palm Computers & Internet Experts
Muzahura Frank
Marvin
Marvin
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
